Old 02-25-2005, 03:32 PM
IO Composer IO Composer is offline
Default Crashing when opening up older sessions
Hi.
I've got a bunch of old sessions that I absolutely need to get into and everytime I try to open them up, PT "unexpectedly quits". Usually when the progress bar is saying something about Altiverb. Am I hosed?
-Jamey
Jamey Scott
Dramatic Audio Post, Inc.
Burbank, CA
IMDB
Old 02-25-2005, 04:02 PM
KingFish KingFish is offline
Default Re: Crashing when opening up older sessions
I've run into this lots unfortunately.
the only work around i have found, it to make a folder called TEMP on the desktop.
in finder, navigate to System HD/Library/application support/Digidesign/plug-ins
and drag all of your plugins out of that folder, into the temp folder you've created on your desktop.
Load Pro-Tools
Load your session
Remove the italicised plugin causing the crash
Save session as sessionNameFixed
Quit Pro-tools
dump the plugins back where they belong (HD/Library/application support/Digidesign/plug-ins)
open your "Fixed session" insert a new instance of the plugin, and reset parameters the way you had em.
This happens for me with older sessions with Auto Tune, and ChannelStrip
Importing Session data, would crash PT, simply Re-saving the session after removing all the plugins, restoring the plugins, opening the session, and activating the plugins, would crash pro-tools.
The above meathod is really the only work around I have found for this in PTLE 6.4 and PT TDM 6.7
If you find another way, let us know about it.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 02-25-2005, 04:18 PM
Seeee Seeee is offline
either that or try to create a new session then import the tracks.
Old 02-25-2005, 05:14 PM
Thanks much for the detailed reply. I know that the culprit plugin was Altiverb, so it was pretty easy to pull that out and open the file. I guess the new version of altiverb is incompatible with the old version's settings. This particular session required a remix due to the fact that I couldn't remember the reverb settings but I think this mix is better so it's all good. Would have preferred not to spend the afternoon remixing tho
Cheers,
Jamey
Jamey Scott
Burbank, CA
IMDB
Overview redraw when opening older V7 Sessions georgelegeriii Pro Tools TDM Systems (Mac) 2 12-26-2009 03:41 PM
Opening HD 7.4.2 Sessions on Older Versions Lumin Pro Tools TDM Systems (Mac) 2 10-30-2008 02:13 PM
Secrets to opening older sessions in PT 7 HD Chap Pro Tools TDM Systems (Mac) 8 07-29-2007 09:17 PM
Older sessions crashing 7.3 (all) PLUS - a stoopid question. tsugi Pro Tools TDM Systems (Mac) 2 04-05-2007 06:32 AM
PT7 crashing when opening older sessions mwingerski Pro Tools TDM Systems (Mac) 4 02-18-2006 03:54 AM
