Channelmatrix misbehaviour PT8
Since PT8 the channelmatrix misbehaves and sometimes goes dead.
Anyone familiar with this issue ? If yes, have you fixed it and how ? PT8, MacPro 8 core 2,8 ghz, ProControl 32 fader editpack, HD accel 6 |
Re: Channelmatrix misbehaviour PT8
Digi Please Help. Have the same problem and "hide all group unhide" solves problem. Channel Matrix fails after bank select.
PT8, G5 Dual 2.5ghz, ProControl 32 fader + editpack, HD accel 2 + Core 2 |
I'm going to need you to be a little more explicit in your explanation of what's happening. When you say it 'goes dead' - what happens exactly? What are you doing when this occurs?
Digi,
Thanks for your reply... after doing a "Nudge Bank Select" and move tracks across fader packs or master fader and return to track ... the channel matrix does not work. No track select, mute, solo etc does not function or LED lights. After hide and unhide "all group" it works normal. This does not happen in Tiger 7.4. Will be glad to provide more info. Thanks M |
did you ever find a solution to your problem. It seem like i'm having the same problem.
Hi vudo,
No it is in the hands of Digi under a support contract. To save you and others time the following has been tried with Digi: 1. 7.4 and 7.42 Pro Control controller personalities. 2. Trash prefs 3. Reinstall Leopard + PT 8.0 Thank God I have 7.4 on a separate drive. It is very annoying to view go to Master Faders and then return to lose functionally of the Channel Matrix.... the great worksaver of Procontrol. I hope 7.4 is not the end of support! m |
6.7 is Great ! Channelmatrix restored | Mano | ProControl, Control|24, Command|8 | 1 | 11-12-2004 11:20 AM |
Bug in channelmatrix -behaviour since 6.4 | Mano | ProControl, Control|24, Command|8 | 2 | 08-06-2004 11:36 AM |
