Old 06-09-2001, 05:15 AM
synesthesia synesthesia is offline
Default HELP!! headphone mix out dont work!!
OK, so I have connected my artists cans to the aux out on the back, but I cant get any signal out to them!! Have tried many combis of 'monitor to aux' on & off, listening to protools sources 12, 34, 56 - get a signal that sounds like a million delays from 5&6 (with the mix out routed to 5/6 etc) and am at wits end. HELP!!! Thanx
Old 06-10-2001, 10:54 AM
McMasters McMasters is offline
Default Re: HELP!! headphone mix out dont work!!
What is connected to the aux in?
What is connected to the aux out?
1 Connect the Pro Tools output pair that you
have designated as the cue mix buss to the
Control 24 AUX IN inputs.
2 Connect the Control 24 AUX OUT L/R out-puts
to the studio cue monitoring system. This
signal’s level can be adjusted with the
Control 24 AUX LEVEL control.
I suggest setting your aux sends used for the cue mix to pre-fader. That way you can jerk around with levels in the control room and not goof up their headphone mix.
PT9 and 003 Drivers (DONT WORK) Barry Johns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 02-01-2011 04:31 PM
Soundreplacer dont work koka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-27-2008 03:11 AM
Main FX bus on/off dont work Eric Hector Virtual Instruments 1 03-22-2007 08:39 AM
mon out dont work sherryAA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-01-2002 12:06 AM
Preferences dont work! cinecity Digidesign Hardware & Software 1 07-08-2000 06:39 PM
