Old 01-09-2002, 10:42 PM
john longland john longland is offline
Default WAV file format
IS the WAV file generated by PTF PCM format or ADPCM format ? Is there a way to set it to generate PCM format ? Reason is : I am using Nero CD-buring software and Nero does not accept WAV files generated by PTF.
Any suggestions ??
Thanks !
Old 01-10-2002, 01:41 AM
guessi guessi is offline
Default Re: WAV file format
it is common PCM-format.
the PT-wave-file simply contains a lot more information than a "normal" one. but every application that regards the wave-standard should be able to read it anyway.
so perhaps you take a look at a little tool I wrote to process audiofiles. besides other purposes it can be used to remove all the additional information leaving just the wave-header and the sampledata. info and download: http://www.leipzig.primacom.net/gues...t/digiconv.htm
when you're unsure about the appropriate settings just ask again.
Old 01-10-2002, 03:23 AM
clausiii's Avatar
clausiii clausiii is offline
If you have another audio programm s.a. Wavelab, Cubase etc., open the wav´s and re-save it again.
I think that the wav will get a new header.
What kind of wav did you make? Did you bounce to an interleaved stereo file or stereo split?
Do it interleaved...
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
HTML code is On
What is the TFX File Format? fly_with_v Eleven Rack 10 04-15-2013 09:17 PM
Wave Format Extensible file format? Joe Mendelson Post - Surround - Video 8 01-07-2008 05:18 PM
*.tfx file format??? Jody Stevens Virtual Instruments 3 10-09-2007 09:36 AM
.VOX file format pk_hat Pro Tools TDM Systems (Mac) 4 11-23-2004 12:56 PM
.wav file convert to .mid file format Eddie YP Pro Tools TDM Systems (Mac) 1 03-17-2000 12:33 AM
