  #501
Old 01-28-2004, 08:10 PM
Matt Whritenour Matt Whritenour is offline
Default Re: Best Laptops for PTLE
woudl a 3gig P4 be more powerful
then a 1.6 centrino?
because i've read posts about peoples
1.5 centrinos outperforming there 2.4 gighz
P4s so i dont know what chip would be better
to get
www.klarityrecordingstudios.com
  #502
Old 01-28-2004, 08:33 PM
EDurney EDurney is offline
djd2
How is the performance of that Notebook in a real world escenario?
i mean ...is it stable??....
can you run Soft synths ( if you use them) on it?? (Sampletank,etc)
How is it at 128 samples buffer setting? (Davec test)
too many questions??
Pro Tools 10 / Duet 2 - Eleven Rack - Mbox 2 pro
MacBook Pro 2.2ghz Quad Core/ 8gb RAM/ 750HD
Pro Tools 9 HD / 192io / C24
Mac Pro Quad 2.66 / 8Gb Ram
  #503
Old 01-28-2004, 09:15 PM
sventvkg sventvkg is offline
I am getting the 807 emachines laptop after the weekend and I should have some DaveC Results soon after...Patients!!!!! I'll bet it gets close to the 1.7 centrino...We'll see...
Sean M Mormelo
www.seanmormelo.com
[email protected]
  #504
Old 01-29-2004, 11:21 AM
mahoney mahoney is offline
awsome sean
if the results are stable and you can use it on everything (like the apps stated above by the last poster) then this is def. the machine to get. it is so cheap at best buy
http://notebookforums.com/forumdisplay.php?f=22
there is some lengthy discussion about the build/weight/heat/battery over there
this thing is, light , small, last long on batteries and flys like a mo fo
and its cheap!!
i think im sold
QUE- someone to come in and tell me some information i don't know and shatter my confidence on the decision lol
  #505
Old 01-29-2004, 12:15 PM
djd2 djd2 is offline
djd2
I used it in a real session yesterday no problem. We were overdubbing vocals on a session that I started on my 001, a full band with about 24 tracks total. I had no crashes or latency troubles. I started a rough mix using assortments of eqs and comps and an aux for reverb. Didn't have to worry too much about CPU useage. I was at it for about 3 or four hours, at no time did we suffer computing issues just talent issues . I was using a dual monitor setup I have an external 19" trinitron.
I am used to running a 001 system on an AMD XP 2100 512megs of RAM, I would say it was a solid as this system and I never had trouble with that setup.
This new setupo is a 002rack with and Compaq x1010 centrino 1.4. I think I was working at 256/85% for overdubs but not sure, I usually mix at 512/85%.
Dave
  #506
Old 01-29-2004, 12:34 PM
audiocase audiocase is offline
ok.here is my upadte on that Toshiba laptop purchase,using the mbox:
The Laptop in question here is:
Toshiba Satelite A20
P4 256mb ram
DVD/Cdrw
40gb(4,200rpm)
Integrated[shared] video
15" LCD
XP pro
Symantec Norton Anti-Virus
ok,performance wise:
After installting PTLE 6.1.1,it takes about 70 secs to start PT.I couldnt even do the test because it wont record at all-It comes with the HW buffer should be lower thing even at the highest number.
Verdict: This lappy is a big "zero"
Curiosity: Why does it come up with the additional message," CPU busy with other tasks"?
But I also tried the it with the mbox and logic5.5.1.It recorded,but it was quite distorted.I suspect this laptop could work with a PCMCIA audio interface like Echo indigo I/O.
Be ready to capture the magic... even in your sleep.
  #507
besmusic besmusic is offline
Hi Gents
I'm getting so much out of this thread, thanks. I'm patiently waiting for Sventvkg to post his DaveC results, that will be very interesting. Has nobody else done the DaveC with a AMD64?
My question for you gents: On the first page Allen posts the results from Dec. for these two laptops...
>Best Performers: (updated 12/6/03)
>Dell Inspiron 8600 Pentium M 1.7Ghz with ATA100 7200rpm DaveC= 32+15 DVerb= 42
>Acer Pentium M 1.5Ghz with external firewire ATA100 7200rpm DaveC= 32+16 DVerb= NA
...but for some reason the Acer didn't have Dverb results ("NA"). Why do some test results include Dverb counts and some don't? Unexplained, it makes it seem like the ones that have Dverb results are better...
Thanks for any insights...
Pete Turok
Powermac G5 dual 2.0 & Dell i8600
PTLE 6.2.2, 002r
  #508
Old 01-29-2004, 02:23 PM
JPS JPS is offline
AudioCase, I don't think anybody was really expecting a laptop with an Ali chip in it to work, but since this has a Pentium chip I was wondering if you disabled Hyperthreading in the BIOS?
John-Q6600,GA-EP35-DS3P, Zigmatec S1283: 235 D-Verbs @ 2.4 ghz
  #509
Old 01-29-2004, 03:54 PM
The TOSHIBA setup wont allow me to go into bios-I've tried the DELETE key during reboot to no avail.
I'm not sure this ALI chipset thing would work with othet audio inteface(usb)
  #510
Old 01-29-2004, 09:41 PM
im pretty sure its not delete
its like F2 maybe F8
but im pretty sure its F2
USB support with Pro Tools 9 Laptops moldenke Pro Tools 9 4 11-18-2010 04:46 PM
Dell Laptops and Pro Tools sgladm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-03-2006 10:32 AM
Best laptops for Pro tools felixflank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 04-07-2006 06:41 AM
alien laptops and pro tools geefive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-29-2006 10:17 AM
Pro Tools and Apple laptops Jsalam112 Pro Tools TDM Systems (Mac) 1 04-08-2002 09:28 AM
