#41
Re: Heat on a 'freeze track'
I converted my recent track to midi+audio track for each instrument and it got big and confusing pretty fast. If Avid allows us to simply wrap those in a folder some day, then there'll be no issue.. that's the way I'll go. For now I'm going to commit and hide/inactive the source VI track.. problems solved. If I need to change melody I can unhide/enable track then proceed to re commit. It's workable for now and means heat on all tracks. Of course if I could afford an ultimate SUB, 256 audio would give much more leeway.. With PT being able to put all the audio tracks in ram the audio playback performance is exceptional. 75mb of audio per 5 minute project for 44K 24 bit means only 9600 mb for a full 128 track audio session at 5 minutes.. I set my disk cache to 8GB so am covered for almost all ram streaming with full track count :).
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
#42
Yeah that's what I do, you just have to remember to copy any changed plugins and automation over to the original instrument track, or the new audio track.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
#43
I do NOT print VI's with insert effects under any circumstances, so if that's what you meant that's not an issue for me. My only cpu issue is with VI's, not FX.. with maximum 128 audio tracks even my little 8 cores are enough to put all the FX i want.. plus the 30 UAD dsp.. this is why I don't print with effects and just the raw audio and then mix that. By the time I print to use heat, it is mix down time and the melodies and chords are likely all done. It would probably not be a common thing for me to have to go back and change it anyway.. Likely all the editing and song structure I need once VI's are printed could be done on the actual audio tracks. Cheers.
#44
PS heat actually sounds really good when used subtly.. I have not found a situation yet where the mix sounds better with it disabled.. It adds just this, well, subtle sheen to polish it all off.. I am driving clockwise but not using the clockwise tone as that's too bright.. I am using an 11 o'clock tone and about a 2 o'clock drive.
#45
Commit or Freeze with Heat (HDX) causes Pro Tools HD to hang | DetroitT | Pro Tools HDX & HD Native Systems (Mac) | 23 | 10-18-2017 02:51 PM |
Track Freeze & HEAT | sadateffendy | Pro Tools 12 | 1 | 03-15-2016 04:52 PM |
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
Heat vs Master Track Plug In | SWSPHX | Pro Tools TDM Systems (Mac) | 1 | 08-20-2010 02:12 PM |
Track offset menu or track freeze as workaround for ADC? | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-27-2008 12:19 PM |
