Old 03-15-2016, 04:18 PM
sadateffendy's Avatar
sadateffendy sadateffendy is offline
Default Track Freeze & HEAT
Hi guys, anyone experience Heat on the Audiotrack getting bypass(grayout) while Master module Heat is on, I used track freeze for all the audio tracks & auxiliary input. thanks
Old 03-15-2016, 04:52 PM
Default Re: Track Freeze & HEAT
Can I use HEAT Post, while doing Freeze up to insert on some plugins. thx
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
Heat on Aux Tracks? Bus output to Audio Track? Rule62 Pro Tools TDM Systems (Mac) 9 09-19-2011 09:22 AM
HEAT question--is it pre or post on each track? bashville Pro Tools TDM Systems (Mac) 3 01-20-2011 07:53 AM
Heat vs Master Track Plug In SWSPHX Pro Tools TDM Systems (Mac) 1 08-20-2010 02:12 PM
Track offset menu or track freeze as workaround for ADC? mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-27-2008 12:19 PM
