Starting to like this Eleven Rack I just bought!
Hi guy's my name is John and I'm new to the forum and the 11Rack as well, been wanting to try this for a while and had chance to pick this up at a good price ($250). It's still Ver 1.03 and it didn't come with Pro Tools which is fine by me, spent a few days just figuring this out but I'm starting to get the hang of it. Found a patch I liked it's D4 Black Hat and all I tweaked was the microphone I thought that's all it needed, I recorded this direct into my mixer then into my computer. Check it out if you want let me know what you think...
I think this box will be a lot of fun!! https://soundcloud.com/j-lagrassa/black-hat |
Re: Starting to like this Eleven Rack I just bought!
Sounds great, yes they are nice boxes. And you can use it with any DAW, it does not need to be Pro Tools.
I like the tone, but personally I'm not into 'shredding' for shredding sake. (no disrespect, you are clearly an accomplished musician).
Lately I've been using my 11R in conjunction with a Marshall JMP-1 and getting some nice blended tones.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Via the efx loop?
No, for live setup I'm using a Tonebone Radial 'Switchbone' (ABY Box) to split the guitar signal to feed each unit, running to their own discrete FRFR Amp/Cab. I get the choice of running either one separately or both in tandem.
I'm looking into swapping out the Switchbone for the Voodoo Lab GCX Audio Switcher & Ground Control so I can also introduce my Mesa 5/50 combo into the mix as well. It may sound like overkill but believe me the blends I've been able to get are mind blowing! Or as stated already, I can keep each separate for their own distinct sounds.
I thought about using mine in the loop of my Marshall and may still be an option, I have a couple of Alto TS112A and those sound very good with the 11 Rack once tweaked. I will take my time and get use to the 11 Rack before I decide to use it with my band I still need a controller. Last edited by J.LaGrassa; 10-20-2014 at 04:48 AM. |
I played mine into my Lunchbox amp. Didn't look at the book just dialed about... Think I found a couple of tweak able patches. The chorus / flanger sounds good. I will stay in the studio until I can get a rack for it. Certainly a great deal to get into Pro Tools
Try the SR. Verb I believe it's called - great sounding verb IMO
I liked both. my stage amp has a great spring. I love the Lunchbox... my back up amp.
Found a used but still like new Midimate online yesterday so hopefully I will have that in a couple of days, doesn't seem to bad to program and I like the size of it.
Bought: Used Eleven Rack... No Pro Tools LE | msantarc | Eleven Rack | 5 | 11-21-2012 04:00 PM |
Bought used Eleven Rack, Expansion Question... | alpjr | Eleven Rack | 2 | 04-25-2011 04:35 PM |
Just bought an eleven rack- first impressions | Chris Beaver | Eleven Rack | 5 | 01-21-2011 03:29 PM |
Bought an Eleven Rack and Pro Tools won't install, help!!! | kgtele | Pro Tools TDM Systems (Mac) | 1 | 06-11-2010 01:33 AM |
Just bought an Eleven Rack | Kaigne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 01-09-2010 07:36 PM |
