Old 08-17-2009, 09:20 AM
sircharles2 sircharles2 is offline
Default I'm having problems shutting down. PT freezes upon exiting
For the past few weeks every single time I exit PT it freezes.. No matter which way I try it, close session first then file exit, or close session then use quit command, or trying to exit while session is still open.
If anyone has any tips let me know.
i'm running PT 7.3.1 on a Q9550 core2 duo (quad) 4g of ram dedicated audio drive and sample drive. Everything is usually pretty stable but this has been happening recently.
Help
PT LE 7.3.1 M Box
Intel Q9550 4G DDR2
Akai MPK 49
Grand Rapids/Lansing/Detroit MI hiphop head
Old 08-17-2009, 09:44 AM
epu epu is offline
Default Re: I'm having problems shutting down. PT freezes upon exiting
I have been having this problem a LOT lately and it is really driving me insane.
Macbook Pro 15" (Mid 2014)
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 08-17-2009, 09:46 AM
sw rec sw rec is offline
SOMETIMES I get a white screen, but if I walk away for 10-15 minutes it'll eventually close the session. Annoying to be sure. Embarassing if you have a client sitting there....
Old 08-17-2009, 03:00 PM
Spyda KB Spyda KB is offline
Just a guess...
Do any of you guys happen to have multiple USB MIDI devices connected? I know the Akai USB devices causes this problem when on a shared USB connector.
- KB
Citizen K Productions
http://www.citizenkpro.com/
Old 08-17-2009, 04:19 PM
Just a Midisport 8X8s and a CD burner here. It never did it with 7.4
Old 08-17-2009, 04:21 PM
I have plenty of USB devices connected but all are directly into the PC...
any other suggestions?
PT LE 7.3.1 M Box
Intel Q9550 4G DDR2
Akai MPK 49
Old 08-19-2009, 03:34 PM
For testing purposes...I would suggest disconnecting the Akai (and any other Akai device) and see if PT shuts down properly. Make sure to start and shutdown PT without any Akai device attached.
- KB
Pro Tools 10 Delays or Freezes when exiting application abrstudios Windows 11 10-25-2011 02:20 AM
Mbox 2 freezes mac when shutting down vinhluu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-14-2011 01:17 PM
Audio problems when starting Windows & shutting down...help! jasonguitar Pro Tools M-Powered (Win) 0 05-01-2007 06:39 PM
6.1 freezes on new computer - no problems on old sykofiddle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-29-2006 02:41 PM
Problems shutting down Pro Tools Eduardo Apolonia Pro Tools TDM Systems (Win) 6 03-27-2001 04:34 PM
