Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 10-21-2008, 11:39 AM
lanhet lanhet is offline
Default PT will not open or create a session on external drive
I have had a problem since doing a complete fresh install on my 1.42DP G4 with OS10.4.8 and PT7.1 M-Powered. I cannot create or open a session on a drive that is not connected to the same controller as the OS drive. I'm not absolutely sure that the problem wasn't there before as I always record to the same drive and use the others for backups. I seem to remember that I opened sessions on my backup drive from time to time to check things.
I cannot open or create a session on a drive that is not on the same controller as the OS drive. Same for a FW drive. I have a second drive on the OS drive controller and everything is fine with that one, same for the OS drive. I have another drive on the second controller and that one won't work.
If I try to create a session I get this message:
"Could not create new document because assetion in "Sys_FileUtilsMacOS.cpp", line 1178 while setting attributes for (session name) while creating (session name)"
If I try to open a session I get:
"Could not complete your request because Volume not found (-35) while opening (session name)"
If I copy a session (drag and drop copy) to a FW drive and take it to another studio, I can open it there, but I can't open it on my system.
I also use Digital Performer 5.12 and I have no problem whatsoever using any drive that program.
I'm puzzled...!!!
Old 10-21-2008, 04:36 PM
Default Re: PT will not open or create a session on external drive
Well, I didn't expect to provide my own answer...
The problem was that both drives that were not working had names that contanined an "é" and apparently ProTools doesn't like that. I was running PT6.8 before doing a fresh install and uddating to 7.1 and I suspect 6"8 didn't mind the "foreign" characters...
I cannot create a new session, I am not allowed to save in external fw800 drive alidav Pro Tools 10 4 06-21-2013 10:22 AM
Pro Tools 9 won't open or create a new session G-Lay macOS 9 05-09-2011 04:48 PM
Can't Open Session from External Drive (Volume Not Found -35) PT 8.0.3 KeithKenny Pro Tools M-Powered (Mac) 9 08-06-2010 07:21 PM
ProTools 8 crashes when i try to create or open any session bendik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-14-2010 09:37 AM
Can't open or create a session on new hard drive Pierre B. Samson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-25-2005 07:24 AM
