#21
Re: Invalid fades on playlist "?"
The weird thing is that these fades are always at bar #347222.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#22
I've seen this in super sessions (all or most of the reels in a session) with Pro Tools 11.2.1. For me, if I import session data to a new session (and link to media) it appears to resolve the issue. I’d be interested to see if it resolves it for others encountering this issue as well.
#23
We just started encountering this issue in PT 11.2.1 HD with a super session. Session was fine one day, next day it wasn't. Tried importing session data to new session and still same error. Does anyone have an answer to this yet? Multiple threads on this issue dating back many years and still no answers. Especially from Avid....surprise surprise.
I have a dream that one day Avid will upgrade Pro Tools Markers tracks..... |
#24
I may be shooting in the dark here, but....
Sounds like some kind of file corruption. I go to File>Save As, then check the box for Audio Files, and(this is the crucial step) check the box for Main Playlist Only and save this to your recording drive(and NOT inside the original session folder). If this is successful(the copied session saves), close the original and open the copy version. If the copy runs, saves and closes, then you have a good version, and you can be pretty certain some unused audio file(s) is corrupt in the original session. If you are still curious about the ?(and I am too), open the original session and select for all tracks to show Playlists, and look for an audio file with a ? or maybe some undecipherable file name(if the session is huge, this will use up some time, which maybe you don't feel like wasting). Also, open the Clips bin and scroll up/down to see if any clips are off-line(and maybe remove/delete if you find any).
#25
A little more digging and a call to Avid Support to which they were stumped and still haven't gotten back to us after sending a session over, etc....(sigh)... This issue definitely has something to do with region groups as others have noted in previous posts from as far back as 2009 AD. Found some of our 2 pops were part of some region group elsewhere and causing the link to bad fades...I guess. Cleared the region group and it went away, for now. Even though we checked earlier for any existing region groups in the bin and thought they were cleared. Either way, this should probably be addressed by Avid after at least 5 years of people dealing with it, rather than having to search around a session for missing fades and manually remove them from a session that was working fine the night before. Or maybe bring back the "regenerate fades" option that has disappeared from PT11.
#26
Yes ! Where the hell did "regenerate fades" go …? +1 on bringing that back real_eyes.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
#27
The way I understand it, older versions of Pro Tools handled fades by creating a separate audio file. 11 doesn't create a separate file, but processes the level change in real time on the fly. That's why there's no "Fade Files" folder in the session folder. At least I think that's the way it works. If so, it explains why there's no "Regenerate" function -- there's nothing to regenerate. |
#28
Yes that is correct… So how can we have invalid fades ? We now have no way to deal with this error / anomaly.
#29
"Invalid fades (these fades cannot be regenerated if they go offline)
Fade out "" at 347222:14.504 on playlist "?" is invalid because its left contributor is a fade" Still happening Pro Tools 12.4
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12 |
#30
Also in version 2018.4
Invalid fades (these fades cannot be regenerated if they go offline) Crossfade "" at 347222:13.333 on playlist "?" is invalid because its left contributor is a fade. Anyone found a solution yet? Or a workaround?
www.protoolsles.nl |
Has "Some regions had invalid bounds and were adjusted or deleted" been fixed? | meech | Pro Tools TDM Systems (Mac) | 22 | 06-21-2014 12:47 AM |
"Some regions had invalid bounds and were adjusted or deleted" | WildHoney | Pro Tools TDM Systems (Mac) | 243 | 08-13-2013 08:42 PM |
New Mbox Pro "Invalid Authorization Code" | envO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2011 09:57 AM |
"Some regions invalid bounds and were adjusted or deleted" A duplicate Audio Folder ! | acmost | Pro Tools 9 | 0 | 11-13-2010 05:40 AM |
