Old 09-02-2010, 12:25 PM
yoann yoann is offline
Default XMON - Center Channel doesn't works
Hi all,
I have a problem with my XMON, I can't get audio from center channel (channel 3 in surround).
Even if I plug audio in Surround In or Main In, even if I monitor Main Out or Alt Out, I can't get audio from this channel.
If I choose Surround IN as source, the third channel of the center monitor doesn't shows any signal.
I have check my cables (there are fine), and change them, but I haven't been able to get audio from this channel.
Should I suspect a hardware problem with the XMON, or am I missing something ?
Any help welcome...
Regards,
Yoann
Old 09-02-2010, 04:40 PM
Craig F Craig F is offline
Default Re: XMON - Center Channel doesn't works
center channel is Muted but the toggle is to Solo
I've seen it happen
Thank you,
Craig
Old 09-03-2010, 11:39 AM
Hi, thanks for you answer.
Unfortunately, there is no Mute active in the monitor section...
I am now in contact with the technical support, waiting to know if it is a hardware issue...
Regards,
Yoann
5.1 Mix Narrator Center channel Dialogue Centre or phantom Center? kd_special Post - Surround - Video 5 03-02-2011 02:53 AM
D-Control Center Meter and XMON legasafe ICON & C|24 1 05-12-2008 01:20 PM
Center channel from stereo sco Post - Surround - Video 1 12-03-2007 09:04 PM
Xmon - Cannot hear right channel madmac ICON & C|24 9 05-05-2006 05:45 PM
Center Channel and LFE questions talco Post - Surround - Video 5 04-09-2005 08:07 PM
