Old 07-22-2010, 02:38 PM
Boe Larsen Boe Larsen is offline
Default The worst thing on this fantastic system
Hi DUC
Working with audio instruments (rtas), quite often ends in a crash. It usually happens, when I've got 10-15+ instruments going.
NOW - The really anoying thing is that when that happens, and I reboot PT, it won't see the ICON, so I have to reboot the computer. So - a crash like that takes a lot of time.
I remember a while back, somebody mentioned that DIGI were working on an improved rtas engine... maybe they're still on it.
Any experiences on this?
Best,
Boe
Boe Larsen
Producer
www.millfactory.dk
Old 07-22-2010, 02:59 PM
Stig Eliassen's Avatar
Default Re: The worst thing on this fantastic system
Don't know anything about your issue per se, but EW Play 2.x isn't compatible with ICONs as I understand it.
Old 07-23-2010, 11:00 AM
trombino trombino is offline
I have the same problem with PT not seeing the ICON after a crash. It's really annoying.
Mark
Old 07-28-2010, 03:00 PM
Hanswurstlsepp Hanswurstlsepp is offline
That's really wired. So it didn't help to change ethernet cables ?
http://duc.digidesign.com/showthread.php?t=269736
Since that day, all is fine and I'm using at least 15 VIs per song, too.
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 07-29-2010, 12:18 PM
Hi Hans. I'll try with some cat6 cabels then...
Thanks.
Boe
Boe Larsen
Producer
www.millfactory.dk
Old 08-01-2010, 08:50 AM
Tom Graham's Avatar
Tom Graham Tom Graham is offline
Also, I would power cycle the ICON units at he same time your computer is rebooting - that way, it clears out the ENET bus on the ICONs...
Thanks,
Tom
Tom Graham
Avid Audio Marketing
Pro Audio and Mixing
[email protected]
Check out our Pro Mixing Webinars :
http://www.avid.com/US/resources/pro-mixing-webinars
Avid Pro Mixing Blog:
http://www.avidblogs.com/promixing/
Old 08-01-2010, 09:02 AM
...which is definetely a good gym crawling under the table...
Cheers, STeff
Old 08-15-2010, 07:22 AM
Thanks.
Boe
just curious....did it help to exchange the cables ?
I got one computer freeze and one PT-crash yesterday (one after inserting MelodyneEditor as 7th plug insert .... and the crash while inserting it as 1st and while GUI tries to open) .... but D-command went correct offline after some seconds.
After restarting Mac, and launching PT again. D-command went online again.
Cheers, STeff
Old 08-21-2010, 02:04 AM
Hi Hans
Haven't had the time to test yet, but I will asap...
Best,
Boe
Boe Larsen
Producer
www.millfactory.dk
Anyone use these FANTASTIC sounds Southsidemusic AAX Plug-ins 30 12-23-2013 05:11 PM
PT8 is Fantastic! Thanks Digi ssante Pro Tools M-Powered (Win) 1 01-03-2009 02:57 AM
P.S.A. Here is a fantastic broadcast PPM meter for PT Gary Nattrass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-30-2007 02:46 AM
Pro Tools 7 Is fantastic.!!! BIG D Pro Tools TDM Systems (Win) 2 11-07-2005 03:42 PM
Built New ASUS/AMD system and the ^%&%$& thing won't boot-up audiotracker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-13-2001 05:23 PM
