G5 1.8,MIX plus & expansion chassis
Is there anyone running A MIX plus with an expansion chassis and a G5 1.8 Single. I know it's not supported BUT is there anyone doing this.
Re: G5 1.8,MIX plus & expansion chassis
The answer you seek is in a thread called Power Mac G5 1.8's with Mix hardware?
There are 15 other places to find the same answer as well. New Powermac G5/Mix plus compatability Entry level G5 with a MIX system Who is using MIX on a G5? Mix on a G5? Mix Plus & G5: right size/voltage but no support?! Mix on a Magma/G5 does NOT work Mix Plus on a G5? Using TDM MIX Plus System on G5 w/Panther G5 / Expansion Chassis / DSP Farms Mix Core and G5 G5 and MixCore - Anyone running this Config? MIX CORE & G5 TDM on G5 G5 & Mix+ MIX on G5 But none of those threads are necessary if you read this statement from Digidesign.
Expansion Chassis VS 64 Bit Chassis Latency | Touchwood Studios | Pro Tools TDM Systems (Mac) | 2 | 08-09-2006 05:03 PM |
Digidesign Expansion|HD Expansion Chassis work ok? | Will Russell | Pro Tools TDM Systems (Mac) | 8 | 05-25-2006 02:19 PM |
PCI Expansion Chassis | Bermaster | Pro Tools TDM Systems (Win) | 0 | 06-15-2003 09:18 PM |
usb in expansion chassis? | kal | Tips & Tricks | 5 | 10-24-2000 12:13 AM |
expansion chassis | Mitch Griffin | Pro Tools TDM Systems (Mac) | 2 | 10-11-1999 11:39 PM |
