Aux send plugin order
Hi -
First post for me now that I'm up and running. It seems that if I want to use the Artist Mix to select a plugin for my aux sends in Nuendo, that 2 things are funky. 1. The enumeration of available send outputs is strange. It enumerates them from the last one to the first one, so I have to page through a bunch of outputs I don't want before I get to the one I do. 2. Once I finally choose one of the outputs (say a UAD reverb), when I select it, it does not place the plugin in the first Aux send slot - it puts it randomly down the line somewhere (usually in the 4th or 5th slot). This makes it difficult if I want to see all the plugins in the first slot.... I hope that makes sense. Is there any way to make sure that when I select a plugin that it uses the first available Aux send slot first, then goes down the line? Otherwise I'll have to lay them in by hand. |
Re: Aux send plugin order
Chirp.....
Chirp..... |
insert plugin order | 4times4mil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-13-2006 03:22 PM |
Plugin chain order | Kawi | Tips & Tricks | 8 | 09-28-2005 09:51 AM |
Master track plugin order | Greene | Pro Tools TDM Systems (Mac) | 2 | 07-13-2003 09:43 PM |
plugin order | Greene | Pro Tools TDM Systems (Mac) | 15 | 07-13-2003 10:10 AM |
plugin list order? | HoosierSnd | Tips & Tricks | 11 | 03-15-2001 10:34 PM |
