Old 10-11-2018, 01:26 PM
home_studio home_studio is offline
Default Artist Mix: Faders in touch mode are "crancky"
I got myself a 2nd Mix unit. The first one works flawless.
The 2nd unit (new, out of the box): while writing automation in touch mode, the faders sometime (quite often) stop writing while still in auto rec, while still touching them.
Sometimes it is a physical fight: finger vs. fader motor.
So far it didn't happen in latch mode.
I work on mac pro, latest Eucon version, latest firmware.
Does anyone know what seems to be the problem?
All the best!
2023.12 Ultimate / Mac Pro (Late 2013) / 6 core 3.5GHz / 64Gb / OSX 12.7.2 / MTRX Studio / 2xArtist Mix / PT|Control / Aja T-Tap
Old 10-11-2018, 01:34 PM
Fixius Fixius is offline
Default Re: Artist Mix: Faders in touch mode are "crancky"
I’ve had faders not write, but never had them fight me before. Even on “read” they still move freely. This sounds more like a hardware issue. Since bought new, I’d return/exchange as soon as possible.
Old 10-12-2018, 12:32 AM
EddieJones's Avatar
This sounds like the touch sense isn't working correctly. First swap the power supplies and see if that helps. If not I would return.
Old 10-12-2018, 10:03 AM
Thank you both.
Eddie, can it be a ground problem?
Old 10-13-2018, 01:19 AM
EddieJones's Avatar
Yes..but if the other units are working ok...probably not external
Old 10-14-2018, 03:34 AM
An update: Earth, wind and fire. In other words: the 2nd unit didn't have ground on the AC cable. So far, problem solved.
Thanks.
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
Switching a HD from "transfer only" to "record mode" BretFarewell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-16-2010 12:49 PM
Switching subwoofer from "discrete mode" to "stereo mode"? Slerker Post - Surround - Video 6 02-11-2009 07:04 PM
why isn't there a midi "touch tracks" equivalent for Protools fathermac101 Pro Tools TDM Systems (Mac) 9 04-07-2003 01:30 PM
So Where is this ""WIN2K COMPATABILITY MODE""?? el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2002 03:30 PM
