How to print each MIDI track to Audio? PT9
This question might be obvious.. But I would just like to know the simplest way to do this.
I have my session set up with Kontakt 4, Omisphere, Stylus RMX in stereo instrument tracks, as multis. These are routed to MIDI and Audio tracks through different outputs. Those outputs are then my inputs in Aux tracks I have for each instrument. And then those Auxes are outputted to the Stereo Audio tracks where I would like my printing to take place. I'm not sure if i'm missing something really obvious.. But when I record enable my Stereo Audio Print tracks, I'm not able to hear or record anything! Seems like a very cumbersome process for something that should be simple. Thoughts?... Thanks, ~Sylvie |
Re: How to print each MIDI track to Audio? PT9
In order to hear the record track while in Play you need to select Input Monitor. You should have no problem while recording, though. Double check you busing.
Yea, I'm not running HD so I don't have the Input button... But I was finally able to record when I deleted, re-added, and re-assigned all the aux and audio tracks. Same busing.. Just wasn't working before for some reason. Weird!
Thanks for your response though! |
Quantized Midi FROM Ptls won't print audio to grid? WHY? | D-termined | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-19-2012 02:27 AM |
Recording a click track causes audio files to print early? | doubtful guest | Pro Tools TDM Systems (Mac) | 2 | 03-29-2011 11:37 PM |
how to print a midi track? | shret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-27-2006 05:51 AM |
How To Print Multiple MIDI Tracks to Audio? | vivaknievel | MIDI | 3 | 09-15-2006 01:29 PM |
How does one print Midi to an audio track? | Dan M. | MIDI | 1 | 09-17-2004 08:20 AM |
