Old 05-16-2000, 11:47 AM
Zed Zed is offline
Default PT 4.3/mix/ dsp - what can I expect
Been using my tools for a while but first time I am really trying to mix a project in PT, so I am banging my head with a lack of dsp...on average about 24 audio track/4 aux st i/p and a master fader. Ends up I can run cca 7 eq,2-3 comp,dverb,dly and a st comp.....Just wondering if any of you guyz could tell me is that normal.....
PT 4.3
OS 8.0
BW G3-266
888/24
Thanx in advance
Zed
Old 05-18-2000, 06:57 AM
Cawbaby Cawbaby is offline
Default Re: PT 4.3/mix/ dsp - what can I expect
The more you mix in PT the more you find
ways to burn up DSP.... it reminds me
of an old drug habit. Except more expensive.
Dr. Caw Recording
www.drcaw.com
Old 05-18-2000, 08:01 AM
DigiTechSupt's Avatar
What cards do you have installed: PTIII, PT24, Mix, MixPlus? How many addtional farms?
Brent
Avid Audio Tech Support
Support FAQ
Old 05-20-2000, 09:20 AM
Zed Zed is offline
<BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by DigiTechSupt:
Brent
<HR></BLOCKQUOTE>
Sorry I forgot that little detail
Just a mix core......
Thanx
Old 05-21-2000, 08:16 PM
CUBARA2 CUBARA2 is offline
At least you have a Mix core, i only have 1dsp farm card, and i been in your same situation....
I can´t tell you how i´ll like to have a mix plus or more dsp but in the meantime what i do is using just EQ and Compression in realtime and just in key tracks and always left one Chip empty till the end as an Joker(???). Since the begining i had to konw what i want in generally and apply Audiosuite version of reverb and everything else(delays, etc)(i repeat, this is not a desirable stage, but....).
There´s one advantage on this approach... least plug-ins used better final sound.(i might be wrong)
If i´m working with more than 15 tracks i never use Sends(there goes all my dsp).....
Hey at least you have a Mix core!!! Be happy.
Maybe this is not useful for you, but in my situation there are no other alternative than being creative and use what i have a 110%!!!
Old 05-22-2000, 10:19 AM
Let me preface my post with this:
It is impossible to provide exact plug-in counts for our hardware since there is always a trade-off between which plug-ins are being used in each session.
Each Mix card contain 3 different types of chips (from least to most powerful): NoRAM (1), DRAM (2), SRAM (3). While some plug-ins are able to exist on any of these chips, there are a few that will only instantiate on the more powerful ones. In addition, two other factors which determine the overall plug-in count is Multishell compatibility and the DSP Manager. Multishell is a technology that allows different plug-ins share the same chip. While the DSP Farms are capable of multiple instantions of a specific category of plug-in on a single chip, (EQs, Compressors, Gates, etc), Mix cards are able to load multiple types (such as all previous examples) of plug-ins on the same chip (providing that the plug-in is Multi-shell compatible which all the core Digi plugs are). Lastly, the DSP Manager (introduced in PT 4.3) was introduced to allow the DSP on the cards to be used as efficiently as possible. This entails a "DSP shuffling" procedure which reallocates the card's DSP resources when a plug-in cannot open in the currently available space.
For some numbers (instances per chip):
32 voice Mixer= 1 SRAM
64 voice Mixer= 2 SRAM
Dynamics II: 16 mono/ 8 stereo
4 band EQ: 9 mono/ 4 stereo
Virus: 8 instantiations (stereo) per SRAM
LexiVerb: 1 (SRAM only)
AmpFarm: 1 (SRAM or DRAM) per instantiation
Brent
Support FAQ
What to expect? PT HD-1 pinosmuse Pro Tools TDM Systems (Mac) 8 02-11-2009 05:43 AM
What can we expect with PT7? IO Composer Pro Tools TDM Systems (Mac) 10 10-06-2005 04:59 PM
Is this all I can expect? vlastyn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-06-2004 07:49 PM
What can I expect? a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-01-2001 10:43 PM
What should I expect? AdamW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-14-2001 04:21 PM
