Old 10-25-2017, 04:31 PM
MJP MJP is offline
Default Mapping Physical Input To New Track [solved]
Here's my scenario...
My session consists of 8 existing tracks. I create a new mono analog track that falls at channel 9 on the C|24. On the new track, I assign the input to A1. In order to adjust the gain for the track at channel 9, I have to use the gain pot that corresponds to channel 1 on the C|24.
To solve my problem and align channel controls to new track, I realize that all I need to do is drag track 9 to the track 1 position in Pro Tools. Is this the only way to align the new track to the physical channel? Should I be thinking about remapping the IO?
Thanks,
Mark.
PT 12.8.1 HD Native, Mac Pro Sierra, C|24, HD IO Analog 16x16, HD Thunderbolt
Old 10-25-2017, 05:11 PM
Drew Mazurek's Avatar
Default Re: Mapping Physical Input To New Track
You just need to get used to the fact that the input path and the monitor path where the track returns won’t always line up. This would happen in the old days with an analog console and a tape machine and you just kept track of it all. They call it work for a reason.
www.drewmazurek.com
Old 10-25-2017, 06:59 PM
MJP MJP is offline
Thanks, Drew! I figured it would be one of those things. I had hoped that by magic the channel components would follow the track based on the input assignment. But I also realized that the connections (both input and output) are hard wired between my HD IO and the C|24 and it's not likely that there are internal switching matrixes in the C|24. I'm not familiar with the internals of either the C|24 or the HD IO. I do appreciate your philosophical view about work though!
Old 10-26-2017, 04:13 AM
I blame my mother.
www.drewmazurek.com
No sound on Fast Track Ultra SPDIF input [SOLVED] Nayland FireWire & USB Audio Interfaces (Win) 2 05-30-2014 06:57 AM
audio input tracks sent to one aux track - how do i monitor JUST the aux input track? awhile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-17-2010 07:50 AM
Mapping MIDI Track To Instrument Track Delta Dreams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-08-2007 11:26 AM
Mapping Mapping Mapping! Please Digi, Hear Us... relaxo MIDI 0 11-03-2005 09:44 AM
Track Mapping problem!?! walkingyou Post - Surround - Video 0 08-28-2001 01:57 PM
