Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 05-01-2013, 02:39 PM
MichaelK MichaelK is offline
Default Apogee Symphony word clock to HD Omni - how?
I just bought a HD Native system with the Omni interface along with an Apogee Symphony 16/16 analog. I intend to use the Symphony as the main interface going to a summing buss and the Omni just for monitoring.
I understand how to proceed except for how to connect BNC cables for syncing clock. The manuals for both products are very confusing on this question. Do I...
(A) - Connect the Symphony's WC Out to the Omni's WC in?
(B) - Connect the Symphony's Loop Out to the Omni's Loop In, and the Omni's Loop Out to the Symphony's Loop In?
(C) - Both of the above??
Also, should the Symphony's terminal switch be IN or OUT?
The manuals seem to be saying (B) but they're not clear. The dealer's tech support staff insists that it's (A). Which is right?
-- Michael
PT Ultimate Native 2021.10
Mac Pro 7,1 16-core, 288G RAM
OS 11.6.1 Big Sur
Old 05-01-2013, 03:52 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: Apogee Symphony word clock to HD Omni - how?
A. If you are not connecting the Apogee to the HD Native card with a Digilink cable, you'd use the word clock connection.
B. If you are connecting the Apogee to the HD Native card with a Digilink cable, you'd use the loop sync connection.
Note that if "A" is indeed your situation, the digital mixer or whatever it is you have in between the Apogee and Omni should also be in the word clock chain. But I don't think that "A" is the most effective use of the Symphony in your situation.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 05-01-2013, 05:40 PM
Thank you, John!
-- Michael
OS 11.6.1 Big Sur
Old 05-02-2013, 08:50 AM
Originally Posted by MichaelK View Post
Thank you, John!
No problem. Basically in your situation, both interfaces are connected to the HDNative card, so you just treat the apogee is if it were an HD I/O. So it's interface #1, and the Omni is interface #2... just run loop sync from the apogee's out to the omni's in.
- John
Old 05-02-2013, 10:12 AM
I can see that now. Your explanation made it clear immediately.
The Omni manual reads: "Loop Sync should only be used to chain multiple Pro Tools|HD peripherals together (audio interfaces and SYNC HD or SYNC I/O)," which almost - but not quite - implies Avid hardware only. Then the dealer's tech support response to my question completely threw me off. You'd think by now I'd know better than to ask them.
-- Michael
OS 11.6.1 Big Sur
HD omni from Mbox3 Pro..GREAT!!!...Word clock now? bloodstar57 Pro Tools HDX & HD Native Systems (Win) 2 08-09-2013 02:53 PM
HD Native/omni vs Apogee symphony Matchless Gift Pro Tools HDX & HD Native Systems (Mac) 10 04-16-2011 07:41 AM
4 apogee rosetta's...problem with word clock capellino Pro Tools TDM Systems (Mac) 2 09-02-2008 08:23 AM
Word Clock: Apogee Big Ben vs. Digi Sync I/O vs. UA 2192 SoundReplay Pro Tools TDM Systems (Mac) 6 08-17-2007 09:07 AM
Apogee Big Ben v. Lucid GENx6-96K Word/Super Clock TiPo Pro Tools TDM Systems (Mac) 0 01-17-2006 03:08 PM
