Old 03-12-2002, 04:45 PM
cancedda cancedda is offline
Default Midi notes grayed out with DM5
Help, I just started recording drum tracks with an Alesis DM5 and triggers in PTLE, unfortunately I'm not able to edit notes in edit notes, they appear gray with a cross through them. I can't select, move or extend them. Anyone knows about this?
Thank you. C
Old 03-12-2002, 06:59 PM
John H John H is offline
Default Re: Midi notes grayed out with DM5
Close Protools LE.
Open OMS.
Create a new studio setup, let it auto detect all you're devices.
Make the new OMS setup current while still in OMS.
Quit OMS.
Launch protools.
this should make sure protools can find the device and it's patch name document, assuming you've got one in the OMS folder for that drum machine.
this should solve the problem, if it doesn't try creating a new session in protools and import all the midi tracks from the old one so you've got all notes and you just need to re-select the patches for each midi track.
hope this helps, it's happened to me before and it's quite annoying. I'll be glad to see the back of OMS when we get an OS X version Protools LE.
MIDI Regions Grayed Out? philip888 MIDI 15 10-17-2018 07:50 AM
midi instrument track grayed out...??? gamblor Pro Tools TDM Systems (Mac) 10 02-14-2012 01:00 PM
003 grayed out in Audio Midi Setup alex s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-16-2011 09:22 PM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 10:40 AM
Why are midi notes so small in notes view Gothboy MIDI 1 05-27-2008 07:17 AM
