Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 09-25-2019, 10:07 AM
shaft shaft is offline
Default No audio after I insert a Plugin
Over the last 2 days I have had an issue where I insert a plugin on a track and suddenly audio stops. Usually the problem still occurs after I remove the plugin.I am working on a mix. I worked on this mix for a couple of days before this occurred. I am sending all my tracks to submaster aux and then printing on to a track in pro tools.
My setup:
OS X 10.10.5
Pro Tools 11.3.2
Old 09-25-2019, 09:45 PM
Default Re: No audio after I insert a Plugin
Is this some specific plugin, or just any plugin? You need to do some basic troubleshooting to try to narrow down what's happening. To make troubleshooting easier, start by simplifying as much as possible. Step #1 in that process(for me) would be to route all audio and instrument tracks to the main outputs. If all works fine that way, then you have narrowed things down a bit and you maybe have a routing issue.
Bug: When selecting a favorite plugin insert, the plugin above the one selected opens DJ Hellfire Pro Tools 12 35 08-22-2017 09:05 PM
Plugin/Insert application pl8fixr AAX Plug-ins 5 11-23-2016 04:47 PM
CPU spikes after plugin insert Jperkins Pro Tools 12 23 01-21-2016 05:00 AM
How do I apply Restoration plugin on an insert to audio tack? happs01 Pro Tools M-Powered (Win) 2 05-02-2010 03:04 PM
insert plugin order 4times4mil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-13-2006 04:22 PM
