Old 01-25-2016, 11:02 PM
bryced87 bryced87 is offline
Default Mixing Live Concert (Mic Bleed)
The mics on stage for the vocalists for the live concert I'm trying to mix were not unidirectional so you hear lots of the instruments. The vocalists were also off key quite a bit. How can I add Autotune etc if the music is also heard on the mic? I really need to autotune the crap out of it.
I tried a noise gate to try to eliminate some of the music from the mic bleed and it works a bit not enough
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Old 01-25-2016, 11:11 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Mixing Live Concert (Mic Bleed)
You need to try an audio restauration plugin and see if you can isolate the vocals
Janne
Old 01-25-2016, 11:20 PM
Is that already with Pro Tools 11 or do I need to buy one?
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Old 01-25-2016, 11:50 PM
JFreak's Avatar
Not anymore, DINR didn't make it into 64 bit world. Try to demo some 3rd party plugins
Janne
Old 01-25-2016, 11:52 PM
I just stumbled upon this but it might be only for certain recordings.
I read something about phase cancelation by lining up the vocal track and the guitar track, for example. Then inverting the phase of one of the tracks. Will that cancel it out?
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Old 01-26-2016, 02:39 AM
JFreak's Avatar
You might have luck but it is very hard because the guitar cab was X distance away from the vocal mic so you need to nail that nudging perfecly and then adjust the volume too, so that it is exactly as loud as the spill in the vocal mic
Janne
Old 01-26-2016, 08:53 AM
Honestly, this is going to be very difficult - unlikely you can get much phase cancellation from the close mics, and a broadband noise reduction plug isn't gonna do much for constantly varying musical spill. Best bet for a semi-automated solution might be Audionamix's ADX Tracks Pro. You're talking a LOT of work to get this to happen - I hope the performance/budget supports it!
best,
rich
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 01-26-2016, 09:16 AM
JFreak's Avatar
So the one important question left unanswered is this: is it a problem when you have all faders at unity with zero plugins? If it sounds decent, you could just blend the guitar sound for example from multiple tracks (dont use gate/expander on vox). If it really sounds bad then... lots of work and perhaps not so great results
Janne
Old 01-26-2016, 09:17 AM
JFreak's Avatar
Soloed live tracks usually sound like crap, you just need to learn to live with it I guess
Janne
Old 01-26-2016, 12:28 PM
It's not when soloed. The singers were way off and i mean horribly off.
I managed to find a good noise reduction plug in in Adobe Audition. Doesn't get rid of the bleed but reduces it somewhat so the autotune kicks in better
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Mixing live concert 150ch, losing file connection after backup IDTA macOS 6 05-22-2015 09:27 AM
Recording Live Concert Bilnva 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-20-2004 05:22 PM
Mixing in 5.1 a Concert Audio Concepts Post - Surround - Video 2 01-19-2004 04:06 PM
Anyone using PT for live concert record? postboy Pro Tools TDM Systems (Mac) 2 09-27-2002 05:30 PM
Mastering a live concert John Link General Discussion 12 07-09-2002 05:26 PM
