Old 10-11-2014, 09:47 AM
musicmixer04 musicmixer04 is offline
Default "dynamic plugin processing" Issues PT 11.2.1
Just watched the video about dynamic plugin processing, and figured that it dont work the same at all in my system.
I have a clean install of pro tools 11.2.1 on my macbook pro late 2013 retina. 10.9.4
Running HD Native with Avid I/O 16*16
Im constantly having issues with cpu overload with few plugins, described in many treads on this board
Here is what I discovered compared to the avid video:
In my system, the 4th core is very high in cpu usage while the other cores nearly have any cpu usage at all. It dont look like the dynamic plugin processing described in the avid video work at all.
Dont know what to do to have the cores take equal cpu load. any preferences in PT I should check out?
Anyone have same issue?
thanks
Old 10-11-2014, 01:56 PM
Shan's Avatar
Shan Shan is offline
Default Re: "dynamic plugin processing" Issues PT 11.2.1
Which plug-ins were you using for your benchmark testing?
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-13-2014, 05:11 PM
It looks like this in every session. I do use several VI on instrument tracks.
Old 10-13-2014, 05:25 PM
Emcha_audio's Avatar
Empty your plugin folder except for the basic avid and air plugins that were installed from the fresh install. (which means no Hybrid and the likes from Air) and then test again, if it's working properly continue adding one plugin at a time until you find which one is being wonkers.
At the same time are you on a mac or on a PC? if a PC please post a sandra report.
Manny.
Old 10-13-2014, 05:44 PM
Shan's Avatar
Also keep in mind that dynamic plug-in processing doesn't apply to instrument tracks with VI's.
Shane
Old 10-13-2014, 05:45 PM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
Im told this somehow normal behavior. I have this Middle core syndrom on mine... but on my 12 core its the 12th that shows the most usage. my system usage meter shows 24 available cores.
I don't think removing plug ins or anything will help this..
at least not on a mac. Happens to me with just stock avid
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Old 10-18-2014, 07:08 AM
ok I see.
Thanks for helping out. if VI`s are not supported by dynamic plugin processing.
That might explain it.
Thanks again, appreciat it.
Dynamic Delay "Pong" help obx777 Eleven Rack 3 03-25-2013 09:57 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 04:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 01:28 PM
"audio processing is conflicting with other CPU tasks..." gringito 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-09-2002 09:52 AM
Sonovox "voice processing" timelesstracks General Discussion 0 08-21-2002 04:06 PM
