Old 11-21-2013, 04:28 PM
wuwmstudioc wuwmstudioc is offline
Default Avid Artist Mix Slow to Update Display
Hello,
I have recently purchased an Avid Artist Mix and have been trying to get it all set up. For the most part I believe I have it setup properly as I think it is working properly, most of the time.
However, I have noticed a few things that make me question whether it is working properly or not.
1) When nudging between tracks or banks, or making any change that requires the LCD to change, it takes about 30-45 seconds for it to do so. The faders all move right away to the correct track positions, but I can't make any adjustments until the display updates and shows the correct information. However, If i hit the Application button to exit out of Pro Tools and open up my finder window and then switch back right away, it will update it the display right away.
2) I notice the instructions tell me to use the Select button at the very top by the soft knob, but that bottom does nothing when I press it. Selecting a track is only achieved by pressing the select y button by the faders, also half the time it selects a track, the other half of the time it opens up the Eucon hot key assignment preferences.
Please help if anyone has a solution to this.
I am running Pro Tools 11.0.3 on an early 2013 15" Non Retina Macbook Pro with OSX Mavericks.
I am directly connected to my mac's ethernet port (not through a switch). I followed the instructions on how to do that by changing my network settings.
I did NOT setup the artist mix to have a static IP however, as when I tried to do so, I was not given any of the prompts I should have when I held the Page keys and pressed the power button.
Old 11-21-2013, 05:36 PM
Damosound Damosound is offline
Default Re: Avid Artist Mix Slow to Update Display
I've spent a deal of time on this and finally used a support ticket to fix this. Update to the latest version of the Eucon Software (3.0.1) and then go to /Library/Scripts/Euphonix Scripts/Utils and run the script called cleanEuphonixSystem. That should/did fix the problem.
Damosound
Pro Tools 11.0.2
OS 10.8.4
3.4 Ghz Intel Core i7
32 GB 1600 Mhz DDR3
HD OMNI Thunderbolt
Blackmagic Intensity Shuttle 9.7.9
Old 11-21-2013, 08:26 PM
Thanks for your input. I have noticed I have to constantly stop services and then restart them in order for it to recognize my pro tools tracks, that's not such a big deal to me as I can work around it.
Glad it isn't just me not setting it up properly.
What about the Select key at the top not working?
Old 11-22-2013, 09:31 AM
Thanks kdarby... That worked!
I appreciate you directing me in the right spot.
Artist Control Display error with OSX Mountain Lion bg_isagenix Artist Series 5 10-01-2015 02:58 PM
Artist Control dog slow ianmiller Artist Series 7 05-01-2014 07:29 PM
Artist Mix Display issue Dabbler Artist Series 2 10-03-2013 09:16 AM
Artist Color display dim time tripstation Artist Series 0 01-02-2012 09:09 AM
