Old 06-26-2013, 08:00 PM
griploc griploc is offline
Default Playback recording latency issues in PT11
Hello everyone!
I am having trouble with pt11 native software.
When i record at a low buffer setting(128) my recording is not latent but when i playback the recording it is. No plugins are on the tracks, i dont get it??
Pt 10 works just great, no playback issues
Old 06-26-2013, 08:02 PM
Southsidemusic's Avatar
Default Re: Playback recording latency issues in PT11
Originally Posted by griploc View Post
Hello everyone!
System info and all the details you can provide with that,
Chris
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 06-26-2013, 09:42 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Hello everyone!
May I ask what you mean when you say, "my recording is not latent but when i playback the recording it is." Are you saying some tracks are not in time with others?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-28-2013, 02:27 PM
icebox icebox is offline
Gonna bump this because I ran into this as well. I had drum loops in my session and tracked guitar to them with no latency. But during playback there was a good deal of latency. I unchecked 'delay compensation' in the options menu and that cleared it up. Hope that helps.
Old 07-20-2013, 11:17 AM
forgottensky forgottensky is offline
Bump too. Just tracked a session today with Pro Tools 11 using RME Fireface UFX. With buffer size 64 and 128 the monitoring section while recording is okay and not late. But after I stopped the recording and listen to the result, it is late. I cannot provide the details on how many samples it was late, but I can assure that it is late.
Old 07-20-2013, 01:51 PM
Numi Numi is offline
Please Refer to this Thread also: http://duc.avid.com/showthread.php?t=341242
There are many other users experiencing the same thing you are.
Equipment:Mac Mini(Late 2012) and Mbox 3
Audio Drive:OWC TIChip924/FW800
Software:OSX 10.8.5, Pro Tools 11.0.2/10.3.7, Reaper 4 and WaveLab 7
~On The LeVeL~
Old 01-19-2016, 03:54 PM
spaw57 spaw57 is offline
Good Evening:
Scenario: Session opens up in protools 11. Multiple tracks. very few plugins being used. I overdub a vocal track...or guitar track the new tracks simply do not line up with the session - this is driving me crazy!!
iMac i7, 10.8.5, 16GB ram
UA Apollo Duo
Protools 11
LOW LATENCY MONITORING and DELAY COMP checked in PROTOOLS
HW BUFFER set at 32 SAMPLES
There must be a simple solution.
THANK YOU
Steve
Old 01-20-2016, 08:17 PM
your input is greatly appreciated.....
Old 01-24-2016, 03:29 PM
You likely have to debug this one yourself.
What exact plugins are being used? AAX Native or UAD? UAD from Pro Tools or in the Apollo Console?
Trash prefs, try a new session. Do a clap/click test and work out what/where the latency is (turn off ADC and measure the actual latency of clapping along to a click track. If there is a horrible delay it should show up there. Worse case you can manually correct for that.
If you are able to track at 32 samples, you may not need LLM or ADC enabled. So play with all the combinations. First test is what happens when there are absolutely no plugins in use? What happens when ADC is disabled? What compensation is ADC trying to do to each track?
Old 01-24-2016, 04:15 PM
Set the MIX window to show delay compensation(View menu) and make sure compensation is ON(Options menu). Look at the numbers. Recently, my system has been applying compensation that is not called for(longest latency on any track due to plugins is 7 samples, but PT is applying 2048 samples to several, but not all tracks). Its some kind of bug, but its not consistent enough to solve. While recording, I simply turn off the delay compensation
BTW, its happening(sometimes) in both 11 and 12
Recording into Logic Pro 9 via Protools-Latency issues quefijo Pro Tools 10 0 08-22-2012 06:47 PM
Profire2626IO Recording Latency Issues jimmyz Pro Tools M-Powered (Mac) 0 05-07-2009 07:40 AM
Digi 002 & Recording Latency Issues. Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-11-2008 06:14 PM
Latency issues in headphones and recording BretFarewell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-21-2005 12:15 PM
how to manage latency while recording on playback? samrisio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-31-2004 06:06 PM
