Old 03-16-2011, 03:37 PM
crizdee's Avatar
crizdee crizdee is offline
Default 9.0.2 changed all my sessions to bounce multiple mono?
After 9.0.2 update all my session have defaulted to bounce multiple mono files instead of interleaved!
also the default output path for mono was changed (But not the stereo!!)
Everything else seems ok.
Just a heads-up incase you don't realise things have changed
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 03-16-2011, 03:48 PM
WernerF WernerF is offline
Default Re: 9.0.2 changed all by sessions to bounce multiple mono?
Same thing with 8.1.1. I found out when I ended up with multiple mono, instead of stereo interleaved, files of an exported mix.
Old 03-16-2011, 04:58 PM
gonzolagonda gonzolagonda is offline
My file export settings always stick, once set stay to whatever they were before. I did notice that instead of Stereo it now says Interleaved, so there was definitely a change made there. If only my MP3 export settings would stick - they always go back to 128/Fast. Arrghhh!
PT12.4 HD - UA Apollo 16Mkii - UA Apollo 8TB Duo - Mac Pro 2014 6-Core 3.5GHz 16GB RAM - OSX 10.10.5 - Magma ExpressBox3T - UAD-2 Octo - Euphonix Artist Mix, Control and Transport
Bounce stereo/multiple tracks to mono Patlamm Tips & Tricks 4 12-21-2009 11:03 AM
5.1 Multiple Mono Bounce to disc problem glennloopez Pro Tools TDM Systems (Win) 0 05-04-2009 08:08 AM
Using Automator to Bounce multiple sessions..... JasonGough 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-16-2006 05:37 AM
Bounce question - using multiple sessions brandin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-06-2006 07:52 AM
Select multiple mono format to bounce stereo mix? el biciclista Pro Tools TDM Systems (Mac) 19 07-12-2004 05:38 AM
