  #611
Old 08-25-2014, 06:18 PM
Intransit Intransit is offline
Default Re: Delay Compensation bug in PT11 with AOS plug-ins (fixed in PT 11.2.1)
Curious how this fix is going for everyone... I've done a new cue with all tracks in auto-report and all seems good over here. HD Native.
iMac Retina 5K, 2020, 3.6 GHz 10-Core Intel Core i9, RAM 72GB
HD Native PCIe card /// OWC Mercury Helios 3S
PT 24.3.0
  #612
Old 08-26-2014, 06:44 AM
Trailerman Trailerman is offline
Just updated. HDX 11.2.1 crashes every time I try and load the session I was working on in HDX 11.2 not 20 minutes ago.
Have to say, last couple of updates have been less and less stable here. Really hoping this one fixes the issue where ProTools fails to sync to incoming timecode if system delay is more than about 2000 samples, but I need it to just work first.
Jules
  #613
Old 08-26-2014, 04:19 PM
Jules
I feel for you. ADC is working but now I'm getting 'The video engine reported an error. More information is in the video engine log file.'
I scored an entire feature with 11.1.3 without a video error. Is Avid f'ing with us???
  #614
Old 08-27-2014, 03:09 PM
JLC JLC is offline
Please, check this:
http://duc.avid.com/showthread.php?p...29#post2181529
  #615
Old 08-31-2014, 05:20 PM
PMF Media PMF Media is offline
OK, so working on a song over the weekend in PT11.2.1, everything working as expected and - happily - rock solid, I then route 3 acoustic guitar tracks to an Aux master and instantiate a Waves LinEQ followed by a Waves L1 limiter... WOW! massive latency caused by the LinEQ and not compensated for by PT so big timing issues (nearly 3000 samples of delay n the Aux).
I was hoping this issue had been fixed or am I missing something? Delay comp definitely ticked in the Options menu.
all audio tracks, no VI's, no MIDI, 35 to 40 tracks, CPU usage absolutely negligible.
Mac Pro 3.1
16gb ram
SSD system
10.9.3
PT11.2.1
7200rpm audio drive
  #616
Old 09-14-2014, 09:44 AM
Touchwood Studios Touchwood Studios is offline
Bouncing VI tracks and importing them delay is still off. Plus Every time you bounce and import the delay is different.
It's still not working as it should - Again who is testing this do they even know normal session workflows. You HAVE to be to bounce out stems for clients from VI tracks.
CAN THIS PLEASE GET FIXED - PROPERLY!
  #617
Old 09-14-2014, 10:03 AM
Mike496's Avatar
Mike496 Mike496 is offline
Can you expand the process you are using?
  #618
Old 09-14-2014, 12:00 PM
climber climber is offline
Was running 11.1.3 and generally all was fine. Updated to 11.2.1 and while other things were great, I couldn't successfully BTD. Down-dated back to 11.1.3 and things are OK again. Thank goodness...
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
  #619
Old 09-16-2014, 09:04 PM
Every single bounce to disk when recording down VI's the timing shifts and floats around in time - like little fishes in the sea
  #620
Old 09-16-2014, 10:44 PM
Make sure if you were using the bypass auto report workaround… Put the tracks back in Auto Report and get rid of the user area.
I was still getting bounce latency until I did that.
PT 24.3.0
major PT11 delay compensation weirdness. frozenintime macOS 18 02-18-2015 05:38 AM
LE delay compensation plug ins nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-14-2007 11:57 AM
Plug-in Delay Compensation Nard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 10-03-2006 05:18 PM
Plug-In Delay Compensation guitar131 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-31-2005 03:31 PM
Plug In Delay Compensation tj_davies Pro Tools TDM Systems (Mac) 7 09-29-2004 11:51 AM
