Old 11-19-2011, 10:37 AM
bscism bscism is offline
Default Strike 1.5 upgrade
I loaded Strike 1.5, upgrading from 1.0 - the install went fine but when launching strike plug-in I get an error message that says it can't find the content and I need to run the locator. I have done that but the error message persists.
Anybody have an idea of on what I'm doing wrong? Do the content files need to be located in a certain place on the harddrive?
Frustrated, Thanks.
Bruce Scism
Old 11-19-2011, 11:27 AM
Default Re: Strike 1.5 upgrade
Bruce are you running Pro Tools 10?
Aaron Mulqueen - 001 HD Native
Old 11-19-2011, 06:50 PM
No, sorry - I am running Pro Tools 8.5 on the MBox Pro Gen 3 hardware. I run a VISTA 32 bit Dell computer.
Old 11-19-2011, 07:52 PM
Hmmm... did you move the Strike Content after installation? What happens when you install Strike Content to your sample drive and run the Set Content Location application?
Old 11-25-2011, 11:53 AM
TwinSnakes007 TwinSnakes007 is offline
ProTools has to update the registry to set the content location. That's why it's not working. You need to start ProTools in Administrator mode at least once to enable it to update the registry correctly.
Old 11-25-2011, 12:13 PM
Correct me otherwise, that applies to Pro Tools 10?
Old 11-29-2011, 07:26 PM
Space Firebird Space Firebird is offline
I moved my AIR content onto my second internal drive, and was not able to get Strike to find the content (ran the set location utility until I was blue in the face).
I uninstalled and reinstalled Strike, indicating where I wanted the content to go, and it worked fine.
I then realized that I had missed my desired destination by one folder, so I moved it and ran the set location .exe utililty.
It didn't do anything (apart from saying "all done!" - I love that bit).
Anyway, I uninstalled it and reinstalled again, this time putting the content exactly where I want to keep it permanently, and again it works fine.
Had to do the same with Velvet, both operations were executed in order to get the content off of my OS drive.
Set location doesn't work for me at all.
Reinstall from download works great.
Pro Tools 10
Bill
Strike 1.5 -> 2 upgrade guym Virtual Instruments 12 06-27-2013 03:03 AM
Strike upgrade billy101 Virtual Instruments 8 06-01-2012 01:47 PM
Strike upgrade billy101 Virtual Instruments 2 04-14-2012 12:03 PM
Strike upgrade?? j.thomas Virtual Instruments 0 10-19-2011 01:22 AM
Should I upgrade 6.7 to 7.4? Want to use Strike ... TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-22-2008 05:22 PM
