Old 04-13-2013, 10:48 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Idea Scale - please vote - Midi Feature Request
I would like in effect to solo a note or a hit in a drum track and be able to filter my velocity lane for only that note
So I could see for example the velocity for the entire song on only my snare hits - seems like a nice feature - if you wanna see it in PT12 please vote
http://protools.ideascale.com/a/dtd/...79?submitted=1
Daniel
Old 04-15-2013, 10:19 AM
YYR123's Avatar
Default Re: Idea Scale - please vote - Midi Feature Request
Vote it up....guys
Daniel
Old 04-15-2013, 10:44 AM
Carl Kolchak Carl Kolchak is offline
I'm not arguing against the prospect of this feature, or a dedicated drum matrix editor, but maybe you could explain a little more about your workflow.
For example, something I often do initially when programming MIDI drums / samples etc, is get the part down on a single MIDI track (kick, snare, hats etc), and then have Pro Tools split the track by notes.
Now you have a new MIDI track for each MIDI note (i.e. kick, snare 1, snare 2, hi-hat closed, hi-hat mid, hi-hat open etc), which not only gives you the option of having each note trigger a different VI (you could have the kick from BFD, the snare from Battery, the hats from BOOM etc) you can also open the velocity pane below the track lane, and perform the edits you are talking about.
Another often overlooked option, is that you can select MIDI track heights from all the usual choices (Medium, Large, Jumbo etc), but also have the option of single note, allowing you to specify which note you would like to see.
Thirdly, you can also have Pro Tools select every instance of a specific note, and trim their velocity en-masse, for a sledgehammer approach (which in many circumstances is what's required).
Hope that helps you in the mean time.
Old 04-16-2013, 07:45 AM
YYR123's Avatar
wow never thought about trying to do it like that....let me look into it...thanks.
Daniel
Old 04-16-2013, 07:55 AM
Zarabozo's Avatar
Zarabozo Zarabozo is offline
I'm not sure what you mean. I can click on a note on the vertical keyboard in the midi editor and all notes on that note get selected. If I move the velocity of that note, the rest move along proportionaly. I even can drag the note to a different one and all of the notes on that note get dragged to the new note/beat.
I can too make a square selection (buttonDown-dragToSelect-release) when using the hand tool, which allows me to select all notes on the same note for a certain measure only. I can add things to the selection by holding the shift key, again with gragging or just clicking on certain notes.
The audio world is full of (mainly very expensive) placebos.
Latest (subscription) Pro Tools Ultimate on Windows 10 Pro x64
Mbox 3 Pro + Eleven Rack (ERXP)
Asus Prime 299X Deluxe
Intel Core i9-7940X 4.3 Ghz (14 cores / 28 threads)
Ram 8 x 16GB each (128 GB total) Kingston HyperX Fury DDR4 3400 MHz
Dual Samsung 970 Pro M.2 1TB (OS and WIP)
2 x Seagate Barracuda Pro 10TB mirrored for archive and backup
Asus/Nvidia GTX 1080 TI with a single 4K monitor Dell P2715Q
Old 04-28-2013, 08:52 PM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
Funny that this topic came up again. I've had some students ask me about the exact same thing. So, I just created a YouTube video that shows how to approximate a drum editing matrix in Pro Tools. It's not as cool as UltraBeat (etc.) but it's as close as you can get in Pro Tools at the moment.
https://www.youtube.com/watch?v=x3bnbzpKUvI
BTW, this is exactly what Carl mentioned above...
Old 04-28-2013, 09:19 PM
Rufio Rufio is offline
You can do this with groups in Ableton out of the box (and have been for the last few versions).. Just sayin. I included a picture on Ideascale that describes this.
Old 04-28-2013, 10:36 PM
YYR123's Avatar
Okay so I agree the functionality can be had but it seems like there's an easier way to do it then auxing all the many tracks but nevertheless
Daniel
Old 04-29-2013, 04:10 AM
soybalm soybalm is offline
Another benefit is that you can target separate notes with the realtime editor however, I choose to use Instrument tracks exclusively. They have the same flexibility but they seem to have fewer timing issues when using audio plugs with huge latencies. For some reason, my midi tracks get out of sync when using Ozone 5 or the like on the master fader. So I create multiple Instrument tracks but only load one instrument like drums or a multitimbral instrument like Xpand. I assign the midi outputs of the empty instrument tracks in the dropdown menus to the appropriate channel of a multi channel instrument track or just the drum track instrument.
It gets really fun when you assign the the audio out of individual drums to different auxes too! gotta stay organized!
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Avid - Idea Scale - Are you really listening? Dizzi45Z Pro Tools 10 0 10-21-2011 12:16 AM
Noise Gate feature request to vote for mikefont Eleven Rack 1 11-26-2010 09:37 AM
Plugin Idea / Feature Request Carl Kolchak Pro Tools TDM Systems (Mac) 10 07-28-2009 10:13 AM
Feature request - good idea... joesn Pro Tools TDM Systems (Mac) 1 02-08-2001 03:53 PM
