# of Gold plugs/session
Hi all,
I'm looking at buying some plug-ins. The general concensus is that Waves Gold is the way to go for quality and price. Before I go and spend this money I would like to know, realistically, how many real time plugs I'll be able to use at once. Also do these plugs allow you to write an effect to the track so I can use my hard disk space instead of my processor and RAM? I haven't ever reached a point with the audio suite real time plugs where my system can't handle it. But those effects are also not that great. Here's my system- G4-400, 265, 50gb. PTLE, digi 001. Thanks in advance!!! -J |
Re: # of Gold plugs/session
Get them. Youll learn how to mange the powere issue as you go.
Yes, you can apply the fx to the files. you need to get the setting you like in the real time plug-in then "copy" the settings., and then choose the identical audiosuite version and paste the setting into that plug..and process. Make sure you turn the real time version off before you listen agian! ( I usually bypass the RTAS for an audition of the audiosuite file, this way you can go back and forth quickly. And when you are sure you got the sound right, then loose it.) |
As far as I know it is directly relative to cpu speed and memory. I have a G4 400 with 320 megs and have successfully run 10 plugins with four of those in stereo mode, but got a warning that I was approaching the limit (65%) of cpu allocation.
BTY the waves stuff is really good stuff in the hands of a pro. Highly recommend!~ good luck. |
Waves Gold bundle is a pretty comprehensive set of tools, no fancy retro GUI, but tools that do a great job. They'll take you pretty far.
Hey rdatman - what version of PT are you using? You should have your CPU usage set to 85% for maximum DSP. Tony
___________________________________________ Mac Pro 2010 2 x 2.66 / 40GB RAM / OSX 10.13.6 / PT2020.5 / Metric Halo ULN-8 |
Waves Gold Bundle does really rock. Maybe download some demos of "Native Power Pack" and "Pro FX Plus" etc. to see if you want the whole Gold or just maybe get a couple of the aforementioned smaller bundles to see what your computer handles best. Maybe look into the Korg Oasys PCI too. I use as a synth when tracking and as an FX processor when mixing. You could hook it up via the ADAT ports between the 001 and Oasys (like I do) and have 8 (4 stereo) channels of very high quality reverbs and delay and such aux'ed onto PTLE from the Oasys. I was just using it for such a process and the reverbs, and all the fx on the Oasys are just really amazing quality. The DSP on the Oasys also doesn't touch the G4's cpu either. It's not alot of DSP yet it's enough to run a high quality reverb (ADAT 1-2), delay (3-4), compressor (5-6) and anything else on the last buss ADAT 7-8. If you can get one at Guitar Center or online somewhere along with some of the Waves stuff you'd be really set.
Good Luck, Chris
Genuinely, Chris |
If you decide you want the Native Power Pack, check out www.bayviewproaudio.com I just bought it from them for 289.00 including shipping. The best price I have come across so far.
Ron |
Demo session needs AIR plugs-where are they? | Park Seward | Pro Tools 11 | 11 | 06-24-2013 11:22 AM |
Get 002 Factory Plugs If You Have Waves Gold???? | SHC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-08-2005 04:03 PM |
waves gold vs. native gold | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-02-2003 11:15 AM |
waves gold plugs | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-20-2002 11:45 AM |
How many Waves Gold Plugs on Master, before crash with G4 533? | DPM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-03-2002 08:43 AM |
