  #31
Old 05-15-2019, 08:27 AM
GuyPicks GuyPicks is offline
Default Re: 2019.5 is here!!
Still see the jittery screen when playing or recording in both my Mac systems and also on a windows 10 system. Had that before the update to 2019.5 too.
Just throwing these things out to try to help AVID. Hopefully.
I run 3 other DAWs on my systems because of my work and have zero problems with them.
My System
Mac mini M1
OS X 11.6.4
PreSonus 1824c
Faderport 16
Pro Tools Ultimate 2021.12
Studio One 6.5 Pro
Logic Pro X
  #32
Old 05-15-2019, 10:26 PM
mikeyman's Avatar
mikeyman mikeyman is offline
was there a problem with screen jitter? I was wondering about why mine was jittering .Has it been fixed
  #33
Old 05-16-2019, 04:16 AM
All my systems, Mac and PC has screen jitter.
I've just gotten use to it.
And no, it's not been fixed in PT 2019.5 for me that is...
I only threw that out to AVID but they probably already know that.
My System
Mac mini M1
OS X 11.6.4
PreSonus 1824c
Faderport 16
Studio One 6.5 Pro
Logic Pro X
  #34
Old 05-16-2019, 11:01 AM
noiseboyuk noiseboyuk is offline
All has been going very smoothly on 2019.5 on Win 10 Pro until today, when for no apparent reason it no longer launches. Gets stuck on the Audio Engine part of the loading routine. Complete PC reboot, but same behaviour (RME Babyface sound card).
It wasn't urgent today, but will get to get this fixed first thing tomorrow morning - planning a re-install and if that doesn't cure it a roll back. Anyone else had anything like this / have any ideas I can try?
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
  #35
Old 05-16-2019, 12:59 PM
mikeyman's Avatar
no kidding ...it has been a year since and they have not fixed the jitter screen …..I guess they will never fix it...
  #36
Old 05-16-2019, 03:47 PM
the19thbear the19thbear is offline
Default 2019.5 is here!!
Noise, press down N while launching pt. It will then let you select playback device. Happens sometimes.
No need to reinstall
  #37
Old 05-16-2019, 06:10 PM
mikeyman's Avatar
I turned my PC on today with PT's 2018.10 and it was not jittering.Maybe it has to do with a plugin. Ill install 2019.5 and see how it goes
  #38
Old 05-16-2019, 11:40 PM
Thanks - I did actually try that but it was still getting stuck. A reinstall didn’t help, and trashing prefs actually made things worse, it wouldn’t scan the plugins without crashing. I then remembered I’d already encountered exactly this once last year, essentially a total system collapse out of the blue. The solution then was to reinstall then remove all plugins, then close and put them back in. It’s pretty convoluted. I’m going to try one other possible shortcut.
Will likely start a new thread on this for future forum searchers once I’m out the other side, it’s a really vicious little “feature” that a perfectly fine and stable rig can one day fall apart before your very eyes, and all the obvious steps to take actually appears to make you sink deeper into the quicksand. I well remember that feeling last year with a pressing deadline bearing down on me.
EDIT - resolved, new thread here regarding this issue http://duc.avid.com/showthread.php?p...26#post2526126 . Worth making the point that this isn't a specific 2019.5 issue, it's common to multiple versions of Pro Tools.
Guy Rowland
NAB and Connect 2019 Avid General 0 04-14-2019 10:08 AM
Looks like at least 2019 before new Mac Pro K Roche Pro Tools HDX & HD Native Systems (Mac) 3 04-19-2018 06:44 AM
