Old 12-03-2000, 04:30 PM
AnalogTree AnalogTree is offline
Default Re: 001 Mixer Routing Question.
Rather just use a patch bay which is designed for this. Or not
-AT
Beethoven can write music, thank God, but he can do nothing else on earth.~ Ludwig Van Beethoven
Old 12-04-2000, 12:28 AM
bassmac bassmac is offline
Default 001 Mixer Routing Question.
Can I run two channels from my mixing board into one 001 input using a y-cable without signal loss/canceling on either? Of course I would only be recording one signal at a time. I just want to see if I can eliminate some plugging and unplugging of connections.
bassmac
Old 12-04-2000, 12:47 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
Sure, it can be done. Beware of groundloops, phase etc.
Possibly, the strength of the signal will be divided in half...
Arno Peeters
Tape TV Productions
Arno Peeters
Tape TV Productions
Old 12-04-2000, 11:44 AM
KennyB KennyB is offline
I think you might have to put a resistor into the path of each signal that you are mixing together - otherwise the input impedance as seen by the outputs of your desk will be too low (if you see what I mean).....
i.e. if one output is at 0V it will drag down the other output.
Pick a value - 10K ohms should do it....
Old 12-04-2000, 11:18 PM
B-Bo B-Bo is offline
No! It is wrong to "Y in" from two outputs. Kenny B is correct in realizing that there is an impedance issue. I just wanted to better explain what is going on.
Outputs of modern audio equipment are designed with low output impedances. Additionally, modern input stages are designed with very high input impedances. This combination allows outputs to drive long lines and multiple inputs without significant loss of signal. This is the proper use of a Y cable. Feel free to Y the output of your mic pre to both your recorder and your headphone amp!
Using a Y cable to combine output signals into a single input, however, causes problems. Consider it From the perspective of one of the two outputs. From there, I can see the high impedance of the input stage I'm trying to drive. However, I can also simultaneously see the other low impedance output in parallel with that nice high impedance input. The impedance of this parallel combination would be slightly less than the lower impedance. This is way too low for proper operation of this circuit. The result would be a loss in signal, decreased signal to noise, and possibly even destruction of the output stage of your equipment.
The most common place I see this misuse of a Y cable in when people try to "mono" the two outputs of a stereo piece of equipment (usually trying to get a mono send from a stereo console). There are passive resistor networks for combining signals (as KennyB alluded to) but they are more than just resistors in-line, and there is a cost in signal loss. I would point you in that direction, but this is really not what you want for the application you mentioned. For what you want (minimizing patching behind your gear all the time) I really have to agree with AnalogTree's recommendation that you look into a patchbay. Let me suggest that you take the time to learn how to layout a patchbay system properly. With a good "normal" scheme you will minimize patching, and a comprehensive patchbay will inspire you to experiment with signal routings you never would have tried because of the hassle. It's nothing for me to route a vocal I've recorded through my guitar pedalboard's wah on a creative rant.
Hope this helps!
Old 12-05-2000, 10:05 PM
It does help! Thank’s for all the information and suggestions. I figured it may not be that simple. Eventually I’ll get a patchbay, but in the meantime at least my mixers inputs are on the top rather than the back and I can make my changes there. Thanks again everyone.
bassmac
Complicated routing question involving 001, 003 and a mixer Dowski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-13-2008 09:21 AM
003 Mixer Routing/Monitoring Question... bvcreative 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-14-2007 08:39 AM
Simple question about mixer routing RyanC Pro Tools TDM Systems (Win) 7 04-28-2005 07:13 AM
routing to mbox thru mixer question samrisio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-29-2004 06:31 AM
Cabel routing for mixer? johnnyd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-12-2000 11:32 AM
