Old 01-03-2014, 06:14 PM
trainwrecktwostep trainwrecktwostep is offline
Default from PT 10 discussion, just upgraded to 11
I have to keep pursuing this...is anyone experiencing this? I don't mean to imply it's any particular area of the signal chain that is at fault... I would like to figure out why there is a noticeable tone difference in my guitar signal. It's fine through the sound card at the Zero Latency Monitoring stage of the Scarlett, but when switched to DAW routing, at 96kHz/24-bit, in PT11 now (I upgraded), there is a noticeable difference, especially noticeable with palm muting, chugging distortion. How could it be the sound card if it sounds great before the DAW? And my DAW is now 64-bit, sampling at 96kHz? Levels and panning are equal in comparing both stages.
Old 01-03-2014, 08:03 PM
nst7 nst7 is offline
Default Re: from PT 10 discussion, just upgraded to 11
With zero latency monitoring, you're actually hearing the sound before it goes through the digital conversion, similar to running through a mixer. You may in fact be hearing the slight changes brought about by the digital conversion.
Protools 8 New look, old look! Discussion Ale Pro Tools TDM Systems (Mac) 1098 07-07-2009 12:04 PM
Synchronic discussion? daeron80 General Discussion 12 04-06-2006 07:55 AM
Further X-Curve discussion Andy Hay Post - Surround - Video 12 05-22-2005 11:02 AM
The -20 dB discussion Syncman Post - Surround - Video 10 11-12-2003 09:53 PM
Best Mac OS discussion boards? Tim R. Pro Tools TDM Systems (Mac) 8 09-03-2002 10:40 AM
