Old 11-13-2007, 02:02 PM
bvcreative bvcreative is offline
Default 003 Mixer Routing/Monitoring Question...
Hi all,
Please forgive me if this is a simpleton question. I've been using another system previous to this, and the routing seems much different on the PTLE/003. Basically there are a couple of monitor outs on the 003. These default to Analog 1&2 outputs. When I mix I want everything to go out via SPDIF, and I want the monitor outputs to also give me the SPDIF 2-channel mix.
I am aware of assigning multiple outputs to each track, but isn't there any way to globally assign the monitor outputs to mirror the SPDIF out without having to assign each track to multiple outs? I tried selecting multiple outputs on the master fader, but it wouldn't let me do that, at least via the mixer screen.
Anybody know the secret, if there is one? Thanks in advance...
Bill
Bill V.
Macbook Pro 2.5 Ghz, 4GB RAM, Leopard, PT8LE, 003 Factory Desktop Mixer
Old 11-14-2007, 07:45 AM
Default Re: 003 Mixer Routing/Monitoring Question...
bump - hasn't anyone dealt with this issue? Thanks in advance!!
Bill V.
Old 11-14-2007, 08:19 AM
BassBottom BassBottom is offline
If you look in the CoreAudio prefs There is a check box that enables you to mirror analog 1 & 2 output to SPDIF.
It is grayed out in CoreAudio version 7.3.x but is available in version 7.4.
When I installed my PTLE 7.4, I was prompted to update the firmware of the 003.
I think the firmware update has something to do with setting up the SPDIF output that did not work before on 7.3.x
You can upgrade to PTLE 7.4 for $50 and your nightmares will be over.
BTW it works with Leopard on my iMac... I will test it on my tower later.
Good Luck,
BassB
MacPro 8core 2.8Ghz/10GB ram/3TB
Two 23" Cinema Display
iMac 2.4ghz
MacBook 2.0Ghz
DIGI 003/PTLE 8.0.3pr
Old 11-14-2007, 08:39 AM
Perfect, thanks for the response! I just went to a 7.4 "Stretch Your Sound" tour presentation last night. Kurt did a fantastic job with the presentation, and it was amazing, to say the least. I'm gonna download it tonite!!!
bv
Bill V.
10 millionth external DAC monitoring routing question solidwalnut Tips & Tricks 10 06-01-2010 06:23 AM
Complicated routing question involving 001, 003 and a mixer Dowski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-13-2008 09:21 AM
Simple question about mixer routing RyanC Pro Tools TDM Systems (Win) 7 04-28-2005 07:13 AM
routing to mbox thru mixer question samrisio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-29-2004 06:31 AM
001 Mixer Routing Question. AnalogTree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-05-2000 10:05 PM
