Old 03-29-2004, 06:10 AM
samrisio samrisio is offline
Default routing to mbox thru mixer question
is it ok to route thru a mixer and then into the m box? i bought a behringer ub1832FX pro and i'm getting noise from my XV2020...and somewhere else...i have left and right outs into the m box and then my keys, mike, drum pad and sound module thru the mixer...it eliminates having to plug in and out when switching instruments but is it kosher?
Old 03-29-2004, 06:21 AM
Bazzle Bazzle is offline
Default Re: routing to mbox thru mixer question
Sure..It makes patching things a lot easier.You can set the mixer channels that you use a lot,like Voice and guitar or whatever and leave them.So your not always screwing with cables and input levels etc.You can also return the outputs of the Mbox into the mixer, then into your power amp.As long as you don't get a feedback loop happening.
It sounds like your on top of it.I've always had my Mbox set up that way
Bazzle
Old 03-29-2004, 06:26 AM
thanks for the answer..i have a buzzing sound which is driving me nuts...it is intermittent though..how do you track it down and eliminate it? what do you think of the boehringer mixers?
Old 03-29-2004, 06:31 AM
You've probably got a bad cable or ground.I'll leave the Behringer question to those in the know.There's some online as we speak
Bazzle
Complicated routing question involving 001, 003 and a mixer Dowski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-13-2008 09:21 AM
003 Mixer Routing/Monitoring Question... bvcreative 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-14-2007 08:39 AM
Simple question about mixer routing RyanC Pro Tools TDM Systems (Win) 7 04-28-2005 07:13 AM
Mbox routing question lancebrwn General Discussion 8 02-20-2002 12:42 AM
001 Mixer Routing Question. AnalogTree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-05-2000 10:05 PM
