Old 01-17-2011, 10:44 AM
daeron80 daeron80 is offline
Default Re: Pro Tools 9 and Windows XP?
I don't know about Vista, but it definitely installs on XP - with a warning, as AndyJCP said. The main problem is with Digi/Avid hardware, it only works with drivers that are written for Win7. The drivers may or may not fully install on your XP system. In my situation, the program itself worked great - I did a 62-track mix with VIs and amp sims without a hitch - but I had no MIDI hardware I/O through my 002R.
If you've got a third-party ASIO interface, you should be fine as long as it keeps working right. No support if you run into problems, though. Besided, Win7x64 boots faster than XP, almost everything works faster, and the new features make life easier overall. The only thing I don't like is the way it handles file copy/replace. Makes manual backups a pain. But there's a Classic Shell freeware program that solved that for me.
David J. Finnamore
Nyquist was right.
PT 2019.6 Ultimate | Omni | macOS Sierra
PT 2019.6 | Saffire Pro 40 | Win10
Old 04-30-2011, 02:45 AM
bootybandit bootybandit is offline
Save yourself lots of headache.......do a clean install of W7 64!
Healing the world through music.................
Sony Vaio Laptop|2 Core P8700 2.53 Ghz 8 Gb Ram|Win8 x64
PT 9.0.6|Cubase 7|Samplitude Pro X|Reason 5|Spectrasonics|Komplete
RME BabyFace|AxiomPro49|Akai LPD8
Old 08-16-2013, 03:37 PM
trainwrecktwostep trainwrecktwostep is offline
I use 9.0 with XP Pro/ SP3 on a Dell Inspiron with a 1.60GHz processor and 2G of RAM. I don't do much with it, but it's at least ok for creating jam tracks, using an Apogee Jam with ASIO4ALL. It's not adequate for serious sessioners, but I'm making use of my old laptop and a little Randall amp in another room...
Pro Tools 11 on Windows 7 or Windows 8? ianbee Windows 6 08-15-2013 04:04 PM
Upgrade From Pro Tools LE (Windows XP) to 10 (Windows 7) miek07 Windows 3 07-26-2012 07:49 PM
Updating Pro Tools and Mbox from Windows XP to Windows 7 ryanjantz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2011 04:22 PM
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system rhodamorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-21-2010 05:31 PM
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-21-2009 08:24 PM
