Pro Tools 903 Update not recognized
First off, sorry if this is a re-post, I couldn't find the answer to my problem.
Running Macbook Pro, Snow leopard. I just installed PT9 via a download. When PT is launched, it tells me that there is a critical update available, and it sends me to the Digidesign Update Center. I've downloaded the update, but when I try and launch it from the downloads box in safari it tells me the disk image could not be opened. Help! Thanks in advance. |
Re: Pro Tools 903 Update not recognized
Locate the downloaded file on your hard drive:
Pro_Tools_903_Updater_71531.dmg Get Info on the file. If it doesn't say that it is around 1.7 GB, then it did not download completely. If it has ".dmg.dim" instead of just ".dmg" extension at the end of the file name, then it is not a complete download. If it does appear to be a complete download, try opening it this way: Open Disk Utility from Applications/Utilities File > Open disk image Navigate to your downloaded disk image, and see if Disk Utility can open/mount it.
Administrator Avid Pro Audio Community |
It says it's "not recognized."
I'm going to redownload and try once more. |
After redownloading, everything is working fine.
Thanks Avid! |
I'm making the crossgrade to Pro Tools 10, and I have downloaded the 10.2 Mac OSX Installer three times now via Avid Download Manager, and after a definite 'complete' download, I am also faced with "The following disk images could not be opened". I have tried to mount it through disk utility, but it is still no use -- figured I should have just ordered the physical disk, because at this point, I've waited five hours for each complete download, only to find that they are completely useless. I wonder why....help, anyone?
"Without music, life would be a mistake" -Friedrich Nietzsche |
You just missed them Mr T........
They were here just a minute ago......
Projectmix HUI not recognized by Pro Tools 10 | hydrocephalus | Windows | 8 | 01-06-2013 09:11 AM |
USB device not recognized after firmware update! :( | elementalwindx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-28-2011 01:49 PM |
Mbox 2 Pro isn't recognized by Pro Tools in 8.0.3 update | paulbolen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-23-2010 07:27 PM |
Can't find update to 7.1.2 - Mbox 2 Pro not recognized | Podd_Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-16-2007 01:06 PM |
Project mix I/O not recognized by pro tools 7.1.1 | Alec2record | Pro Tools M-Powered (Mac) | 9 | 02-11-2007 08:56 AM |
