Old 07-20-2004, 08:19 AM
wagonburner wagonburner is offline
Default Not getting signal to record
I have had my ProTools system for about a month. My prob is that my Mbox will sometimes not recieve the signal to record. It will playback but when I plug a mic in or a guitar and arm the track it wont show any signal getting thru. I know its prob something simple but what am I missing.
Thanks in advance for the help.
Old 07-20-2004, 09:10 AM
lemix's Avatar
lemix lemix is offline
Default Re: Not getting signal to record
Well, hi Mr. wagonburner ,
First, you are most welcome to our asylum !
-check if the input source selector (mic/line) is in the correct position> cycle through by repeatedly pressing the button !
-are you monitoring input ?? (auto input..in setup !)
happy tooling,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 07-20-2004, 12:39 PM
Thanks Lemix
Its not the selector. That was the first thing I tried. I will check the monitoring signal.
When I bring the mix window up and arm the track to rec I get no signal to the mixer. I've cranked the Input gain on the mbox up all the way but only get line noise. I have also pushed up the faders on the mixer but still nothing.
Old 07-20-2004, 01:26 PM
lemix's Avatar
-Input assignment on the recording track ?
-again.."input monitor status in "setup"
Normal behavior. It is post "tape"
good luck
cheers,
Andrew
No signal can't record theorganist macOS 1 12-02-2012 03:02 AM
PT le 8, I can only get signal while in record mode. pippington 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-06-2009 09:14 AM
got signal but doesnt record! dudeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-01-2007 03:58 AM
Midi Signal In - Will not record jhermais 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-09-2007 08:40 AM
signal Delay while trying to record recwall Digidesign Hardware & Software 5 04-07-2002 03:17 PM
