Old 06-07-2019, 06:02 AM
bing181 bing181 is offline
Default PT 2019 + El Capitan/OSX 10.11?
Anyone get this to work?
Still on a trusty 4.1 Mac Pro, limited to El Capitan. Yes, I know it's not officially supported, but from what I can see, 2019 won't even install. 2018 was/is fine.
Old 06-07-2019, 06:52 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: PT 2019 + El Capitan/OSX 10.11?
Yeah same here running a MBP with El Cap...and PT12.4 w/o issue.
What you could probably do is to flash the MP so it shows up as a 5.1 and then all your issues would go away
Daniel
Old 06-07-2019, 08:02 AM
Yeah, flash the firmware and move to Sierra.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 06-07-2019, 12:34 PM
J_Harry J_Harry is offline
I am using that OS/PT version setup. Seems to be pretty solid, but am noticing some small glitches in user behaviour"
If I have a plugin open, pressing bypass more than twice will actually close the plugin window - annoyingly noticed this while trying to a+b a setting, and the plugin kept disappearing. Noticed with FFproEQ3 and some Bx_ (pluging alliance) Plugins. Anyone else see that ??
Old 06-07-2019, 02:20 PM
clivvy clivvy is offline
using El capitan with pt 2019 ultimate no problems all plugins work and all VIs only thing is i upgrade my mac to a 2012 3.45ghz beast which has 24 cores not going to move to a new osx anytime soon!
Old 06-08-2019, 06:08 AM
Flashed to 4.1 + Sierra ... and away we go.
Thanks for the tips. Been putting this off for a while now, but easy to do and PT/Mac running better as well. Lost a few older apps in the process, but such is life.
Old 12-07-2019, 09:12 AM
mars mars is offline
Not officially supported, but I just decided to test an install of PT 2019.10 on an early 2008 iMac with El Capitan (10.11.6). No issues whatsoever (so far). It seems a lot more stable and faster than 2018.3 which I was running previously. YMMV
Old 12-07-2019, 10:35 AM
I don't know why people still try and use El Crapitan as it's the worst OSX Apple has delivered.
Jack
QAPLA!
Old 12-12-2019, 07:58 AM
smashprod's Avatar
smashprod smashprod is offline
I’m running PT 2019.10 on a MacPro3,1 which can’t run anything above El Capitan. It seems to run fine except I can’t get the Avid Video Engine to launch. Have any of you had success with that?
2019.8 amagras Pro Tools 2019 89 06-10-2019 12:40 AM
SO4.5 Wow vs. PT 2019.5 Justin1524 General Discussion 2 05-22-2019 01:45 AM
Pt 2019 paldry Pro Tools 12 7 05-12-2019 04:18 AM
Looks like at least 2019 before new Mac Pro K Roche Pro Tools HDX & HD Native Systems (Mac) 3 04-19-2018 06:44 AM
