Old 02-05-2004, 06:23 PM
AAR AAR is offline
Default Format Extended or Extended Journaled for PT6.2.3?
How should I format my drives for PT 6.2.3? Mac OS Extended or Mac OS Extended Journaled? And does the same format apply to SCSI, SATA and Firewire?
Mark
Old 02-05-2004, 08:57 PM
Default Re: Format Extended or Extended Journaled for PT6.
I recall reading/hearing from Digi that journaling is a no-no with Pro Tools hard disks. I've also read that it can wreak havoc with dual boot systems when going back to OS 9 (have yet to confirm this - and don't want to risk confirming it ). I would say format OS extended without journaling regardless of interface.
Old 02-06-2004, 02:43 AM
Peter Duemmler Peter Duemmler is offline
I have the system partition journaled and all the other partitions unjournaled.
Works great.
Peter
http://www.merlinsound.de
Old 02-06-2004, 07:46 AM
sdemott sdemott is offline
Default Re: Format Extended or Extended Journaled for PT6.2.3?
It seems okay to journal the startup disk (or partition), but do not journal your audio drives, it drags down the read/write times significantly.
Yes, journaling shoudl work regardless of connection type...it's a UNIX device for recovering from a disaster.
HTH
Steve
Always err on the side of perfection.
Mac OS Extended Format Ok For Windows? Obe1 Windows 2 07-11-2011 06:11 PM
Journaled or Extended... delaplanemusic Pro Tools TDM Systems (Mac) 5 04-14-2008 01:35 AM
EXTENDED Vs JOURNALED HD FORMATS Dual Mackie Storage Subsystems 3 02-25-2005 04:41 PM
Mac OsX Extended Journaled Problem Luis Miguel Storage Subsystems 4 11-03-2004 07:21 AM
Mac OS Extended Format macfoley Pro Tools TDM Systems (Mac) 4 11-09-2001 07:17 AM
