Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 09-28-2023, 03:08 AM
darrancummins darrancummins is offline
Default Bass management & LFE interaction
Hi all,
using the (MTRX Studio) DADman bass management with a 7.1.4 system, I noticed that the LFE channel's Low Pass Filter seems to interact with the Bass Management LPF for the main channels. E.g., the LFE's 120Hz filter slope is overlapping the 80Hz LPF for the front L, C and R channels, and causing it to roll-off more than expected; (approx 6dB dip in the frequency response around 60 - 80Hz). If I increase the LFE cutoff up to 200Hz (max possible value), the bass management filtering then works as expected, and we get a smooth crossover response on the main channels.
(Same is happening on all surround / overhead channels also. Using the default BM preset, all 24dB/oct slopes, Linkwitz-Riley, 80Hz crossovers, 120Hz LFE).
It looks as though the bass managed channels are being passed through the LFE filter, rather than summed in after it? I.e. the "Send to Sub" level for each main channel is actually "Send to LFE"...?
Any ideas how to get around this, or am I completely mistaken? Should the crossover slopes be adjusted to allow for this?
Is there a signal flow diagram available for the bass management & LFE routing in DADman, so I can see exactly how all this is working?
Old 10-01-2023, 12:58 PM
LDS LDS is offline
Default Re: Bass management & LFE interaction
I can't comment on DADman bass management, but I have been caught out by a doubling up of bass management when it was also activated inside the Dolby Atmos Renderer. Just a thought. If you suspect a bug in DADman, I would take it straight to an Avid support ticket.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 10-01-2023, 01:56 PM
BScout BScout is offline
An LFE channel is a discreet channel. The LPF on an LFE affects everything put out by that channel. As a discreet mix channel.
Bass management is splitting the screen/surr channels output and redircting. You are using an 80Hz as a HPF on the LCR (Not LPF as written?) and then sending the rest of the signal to an LFE channel? Well then that output it going to go through the eq on the LFE.
If you have a dual input sub, use the secondary input as your bass management input and set up a separate Sub out to go to that with no filter.
Yes, the most basic answer is yes; things are operating correctly. If you pass a signal through two filters, they will compound. Much the same as if you had a physical LPF on your sub (which is what all the eq on the outputs operate as.) Seems you are expecting the LPF on the LFE to be on the input fed but all the eq is on the output (as if embedded in the speaker.) So no, the bass management output from screen channels doesn't sum after the LFE input is filtered because the filter is at the output.
If you wanted to get really crazy and you don't have a secondary input on your sub, you could redirect the LFE input to loop through a fixed monitor with eq (LPF) applied and the output of that loop summed back (with now no filter on the LFE) to the main set of monitoring outputs. You would just have to set up a separate mon that is REF locked (and hopefully you only have a few 5.1+ inputs since all the LFE channels would have to be put through this for all sources and summed on that side)
Old 10-01-2023, 02:26 PM
gives's Avatar
gives gives is online now
My LFE is a Focal Sub 12 and it's handled in DADMAN with Smaart V8 by Rational Acoustics Room Tune. The Bass Management is handled for the Tops, (0verhead speakers) by my other Sub, which is a Genelec 7370A which is doing a great job here and Dolby used my room for a private event and they dug it!
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 10-01-2023, 02:35 PM
Exactly. 2 subs or 2 inputs to one sub.
Either gives the flexibility.
Old 10-01-2023, 10:19 PM
LDS LDS is offline
Almost 20 years ago the AES published a list of recommendations regarding bass management and LFE. This is what they recommended for accurate low frequency reproduction, as it results in only a potential 60 degrees of phase shift between bass managed and LFE signals. Summing the LFE and bass managed signals should happen at the output, post filtering:
Bass managed signals never become LFE. They might share a DADman output or use the same subs, but they are absolutely two separate things serving different purposes. Putting a 120Hz LFE LPF over the top of the bass management LPF will make it way more difficult to achieve a congruent, full range output cross your mains & subs.
A lot of people are forced to work that way as their subs have built in LPFs that can't be removed from the signal path. I don't see a single good reason why DADman should do it, and I would be very surprised if any of the competition did it. Trinnov definitely don't apply the LFE filtering to bass managed signals.
Old 10-01-2023, 11:05 PM
I can confirm -- just ran a test on a secondary output -- darrancummins situation. LP component of 5.0 channels run through the LPF on the LFE.
So LFE signal from input sums with 5.0 LP signal before hitting the output LFE's LPF filter.
From an EQ standpoint (in the EQ section) that makes sense as that's why it's shown and if you are correcting the sub's frequency response with eqs there (EQ section), it should apply to the output from the 5.0 LP signal too.
Now I've always been for DADman/SPQ adding some virtual busses (which would be necessary to do it the other way), so complain away.
(But this has been how it has always worked and not a "bug.")
Old 10-01-2023, 11:15 PM
Btw, found DAD's block signal diagram for the SPQ system
https://www.digitalaudio.dk/media/SP...-Diagram-2.jpg
Though slightly unclear, seems to be showing a 2 subwoofer/LFE setup and you can see two LPF being applied for both subs in series one pre and post summation.
(It is unclear, though. Not the way I'd draw it as there should be variable symbol and distinction on which LPF filters are which.)
Old 10-02-2023, 02:12 AM
Hi all,
thanks for the very detailed replies! I did some more testing, confirmed the two LPFs (BM and LFE) are indeed in series. I tried a couple of things - changing the LFE filter type to Butterworth gives it a steeper slope with harder corner / knee, so it has less effect down around the bass management crossover point. This, plus moving the BM crossover lower to about 70Hz seems to mitigate the overlap effects.
... I don't see a single good reason why DADman should do it, and I would be very surprised if any of the competition did it. Trinnov definitely don't apply the LFE filtering to bass managed signals.
This is how I always understood it, was surprised to see it happening here.
EQing the sub to correct its overall response is fine, but that's a separate matter. The LFE LPF is just to remove any info above 120Hz from the LFE channel, (as per Dolby) - shouldn't impact the main channels at all. Looks to me like the LFE LPF should be pre-summing...?
Old 10-02-2023, 10:31 AM
This is where my "kludge" method would work. For your main 5.1 make it a 5.2 so you can treat bass management as a different out than LFE out and send both of those .2 channels to an unused output. Then loop both of those back (physically since DADman doesn't have virtual busses.) It could be 1 AES cable (2 ch). Make a second mon entry that just sums the two loopbacked inputs and outputs to your actual sub output. On this one, apply your corrective eqs for the sub for the room. Ref lock it and then just leave it alone.
You'll still only need to manage the first 5.2 for the room for volume but the separate LPF will then be available without running in series for the bass management.
Bass management issue Brandonx1 Pro Tools | MTRX & MTRX Studio 5 08-09-2022 09:19 PM
Bass Management Template AudioPostChris Post - Surround - Video 1 11-13-2009 04:09 PM
Bass Management Chief Technician Post - Surround - Video 9 01-27-2005 08:27 AM
bass / kick and bass management AdamFrick Post - Surround - Video 7 12-26-2001 07:52 AM
Bass Management listener General Discussion 2 11-06-2000 08:07 AM
