Old 08-03-2023, 08:33 PM
Mike Pfeifer Mike Pfeifer is offline
Default Can't get ARA melodyne essentials to work
Hey all, I am technically a new user here, but I actually had another account since the days of PT 5.0.1 (I think).
Anyway, I am not a new PT user exactly, but new to the modern variants.
I have PT Artist 2023.6 on a Mac Mini M2 Pro and Ventura 13.4.1. I am trying to get the ARA Melodyne thing to work, and I cannot figure it out for the life of me.
Here are the symptoms - In a session, I can select an insert and load the melodyne plugin just fine. It is activated per the instructions. I can also open and run the stand alone version of Melodyne Essentials and all show my serial number as it should.
BUT, at the bottom of the session is a Melodyne tab, that is greyed out. Also if I right click an audio track, go to Melodyne - the Edit item is greyed out. The only item I can select is Hide. If I click the toolbar item selection arrow on the far right, the selection box for Melodyne is greyed out.
So, as far as I can tell, Melodyne is activated, but PT doesn't know about it. The Avid Link thing shows a redeem button for Melodyne, not sure if that's how it should be or not. Clicking the redeem button takes me to the activation instructions, but never changes to active.
I have done the following to try to fix it: trashed prefs, deleted PT and reinstall, deleted Melodyne and reinstall, deactivate and reactivate Melodyne.
I'm at a loss here, any ideas what I missed?
Old 08-06-2023, 01:13 AM
chrismeraz chrismeraz is offline
Default Re: Can't get ARA melodyne essentials to work
You need to click on what used to be the "Elastic Audio Selector" in each track on the edit window. It is now the "Elastic Audio or ARA Plugin Selector." Select Melodyne.
Sometimes I don't see the Melodyne data in the Melodyne window after doing this, and I have to go back to the Selector and choose "None," and then choose "Melodyne" again.
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 08-06-2023, 08:06 AM
You have to select the *clip* you want to edit so it's highlighted, then Shift-ctl-a should analyze and allow editing. You can also right click on the highlighted region to get to the various melodyne tools.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 08-07-2023, 12:11 PM
skylar_battles skylar_battles is offline
If you follow all of the activation instructions from the link, it will work.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
New Carbon and Melodyne Essentials included? tekn0 Pro Tools | Carbon 2 05-02-2022 09:51 AM
Pro Tools First Compatibility with Melodyne Essentials 4 rgpinder Pro Tools 12 1 03-11-2017 07:43 PM
FS: Melodyne Essentials btwnthbttns Buy & Sell 0 12-28-2014 03:19 PM
Melodyne essentials v2 $55 YYR123 Buy & Sell 3 11-04-2013 04:53 AM
will essentials work on my system? hardcopy Pro Tools SE and Essential (Win) 7 12-18-2009 11:46 AM
