Spiking CPU Usage - Microsoft OneDrive
If Pro Tools CPU usage is spiking on you and causing errors with playback on sessions that previously worked fine, the first thing I suggest is disabling Microsoft OneDrive.
A recent Windows update enabled OneDrive on my computer and caused the problems mentioned above. I couldn't find the problem and I went as far as formatting my hard drive and reinstalling Windows - but it didn't help at all! Then, when I disabled OneDrive everything immediately started working smoothly. |
Re: Spiking CPU Usage - Microsoft OneDrive
Thanks for the tip.
It's a good idea on Windows to turn off any background sync/transfer process, like automatic updates, One Drive, ... |
On W10 Pro you can use Group Policy Editor to turn off OneDrive.
I simply uninstall Microsoft OneDrive. I use GoogleDrive instead - with no automatic syncing ever.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
I'm using OneDrive all the time on my PT machine with zero problems (it's my daily backup "drive"), so while it's worth checking if you encounter a problem, it's not an "all-in-one" solution.
A side note, I find people (and Avid) to be a bit trigger happy with "disable everything" guidelines. It's not 2001 anymore and PCs/Macs are capable of running background tasks just fine. |
OneDrive/Document install path | FunkzzaJ | Pro Tools 2019 | 3 | 08-21-2022 02:31 PM |
Onedrive rant | JuanPC | General Discussion | 18 | 07-13-2016 06:53 PM |
CPU spiking 11.1.1 | wesm | Pro Tools 11 | 8 | 01-07-2014 05:58 PM |
Cpu spiking | cmotard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-15-2010 08:17 AM |
System Usage CPU meter randomly spiking? | PatrickJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 05-28-2007 12:12 AM |
