Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-02-2020, 12:11 PM
Zak7 Zak7 is offline
Default What is the most recommended MacOS for Pro Tools 2020?
I am on a HDX system
MacOS 10.12.16 Pro Tools Ultimate 2019.6.0
I am on a Mac Pro (Mid 2012) 2 x 2.4 GHz 6-Core Intel Xeon, 32 GB 1333 MHz DDR3
Old 05-02-2020, 12:29 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: What is the most recommended MacOS for Pro Tools 2020?
For the era of Mac I would say High Sierra 10.13.6.
However your current 12 core, how is it for you now?
Old 05-02-2020, 12:35 PM
JFreak's Avatar
JFreak JFreak is online now
Second for HS. You could install Mojave if you have Metal compatible GPU, and if you can install Mojave you most likely also can install Catalina. But the real question is why would you want to do that? HS is very good for your box and fully supported so just stick with it.
Janne
Old 05-02-2020, 01:51 PM
Hi, thanks for the replies
my system is good, I see I can go to Mojave..
But High Sierra may be better now?
I just want to go to PT 2020 if is as solid as PT 2019..I just love track folders...
So I wonder if going to High Sierra would be better than staying in Sierra
I realized this compatibility even with Pro Tools 2019:
Intel® Mac with macOS 10.13.6, 10.14.6 or 10.15.3
So will be better to go to high Sierra I guess...
what do you think guys?
Thank you
Old 05-02-2020, 01:52 PM
JFreak's Avatar
Sierra is no longer supported. Compatibility info here.
Janne
Old 05-02-2020, 04:20 PM
off the wall's Avatar
off the wall off the wall is offline
Mojave if you have upgraded the GPU with a Metal capable one. High Sierra otherwise.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Pro Tools 2020.1 off the wall Pro Tools 2019 141 11-28-2022 01:59 PM
Cannot install Pro Tools 2020.3 (macOS) iz_thewiz Pro Tools 2020 1 04-06-2020 12:16 PM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
