Plug-ins on Venue?
Hello,
Which plug-in types does the Venue allow? I've seen .TDM and "Native" mentioned. Would that be AAX Native? thanks! Nick |
Plug-ins on Venue?
VENUE (the original) requires TDM and special VENUE installers. The new consoles, often referred to as "the new Venue", require AAX-DSP
Re: Plug-ins on Venue?
This is correct and while special VENUE installers are preferred there is a way to install plugins with regular Windows installers by "exiting to desktop". For both generations of desks, you need to install DSP versions and have to have appropriate DSP version licenses.
Can you please tell us how to install plug ins by exiting to desktop? I know its not preferred but would really like to know how to do this. TIA
http://avid.force.com/pkb/articles/en_US/faq/en209523 |
And if you are on S3L you have an extra step, when done you need to launch and go Venue software > plugins and after you have confirmed that the plugin you installed from desktop now appears under plugins available for install then you continue installing from there as normal on S3L. http://avid.force.com/pkb/articles/e...g-S3L-Plug-ins
Thanks Kristo!!!
My pleasure! And if you end up with some nicely working plugins feel free to add their DSP usage to this little spreadsheet I made for us to have an idea of how much DSP plugins need and also what kind of latency they have.
Kristo, I just went through that google doc, and added in a ton more of the supported plugins, and organized it a bit (alphabetical, by manufacturer and by console). In my off time I can go through more of these and update the numbers.
If you wish to change the section I added to 'instances per card' rather than DSP percentage, feel free to take the percentage and turn it into instances per card: (1/0.XX%)*18=Instances Per HDX Card for example 18% DSP usage would be this: (1/0.18)*18=100 Instances Per HDX Card. |
So what I have done is I have started adding a plugin of the same type in empty session keeping an eye on the DSP meter to see exactly when it "spills over" to another chip. That is how the plugin counts in the table are derived right now. And then having one of the instance up I'm adding another plugin to see if they occupy the same chip and share or take out another chip. Thanks again Ryan! |
EQing Vocals - Venue EQ or Plug-in EQ | Tigerspill | VENUE Live Sound Systems | 3 | 10-17-2013 08:13 AM |
Odd plug-in problem VENUE | mbm1987 | VENUE Live Sound Systems | 3 | 04-02-2013 10:11 AM |
Venue 3 and Plug-In Thumbnail Problem | Kenmillerjr | VENUE Live Sound Systems | 9 | 08-08-2012 03:08 AM |
VENUE stock plug-ins | Jason Stygar | VENUE Live Sound Systems | 5 | 02-17-2011 08:40 AM |
Suggested VENUE plug-ins | mariobenipayo | VENUE Live Sound Systems | 10 | 08-09-2009 08:55 AM |
