Old 12-30-2012, 07:46 PM
hyphy hyphy is offline
Default Input Recording other tracks
Hello! I'm new to pro tools and have figured it out for the most part, but I have a major problem with recording. Every time I record, the track picks up other tracks while I'm laying vocals. I mute the track when I record but it still doesn't help, and I can't solo because I can't hear the instrumental. Even if I set up the other tracks to no input(they all share the same output) it still picks it up. I'm sure this is a problem with my i/o but I can't find any solutions. Any help is appreciated!
Old 12-30-2012, 08:01 PM
Default Re: Input Recording other tracks
Are you using open-backed headphones? Have you checked your routing on all tracks?
Old 12-30-2012, 08:23 PM
Originally Posted by albee1952 View Post
Are you using open-backed headphones? Have you checked your touting on all tracks?
No, I am using closed back so it's not leaking. I have checked my routing and it's only using one input, but it's still recording all the tracks.
Old 12-30-2012, 09:49 PM
Please help! This is the only thing keeping me from recording hits on pro tools lol. Better than bouncing audio from another program which isn't good at keeping multiple takes.
Old 12-31-2012, 01:45 AM
crizdee's Avatar
crizdee crizdee is offline
If its a pro tools thing then it can only be 1 of several things...
1. The outputs from the other tracks are routed to the input on the recording track somehow.
2. Any sends on the other tracks are routed to the input on the recording track.
3. Any effects returns are routed to the input on the recording track!
Basically the only way audio from the other tracks can be recorded onto the vocal track is via routing to its input!!
Try a few things like put the vocal track into record and identify which other tracks are being recorded? Is it all of them? Or just some? There's a very logical explanation for this.
The other thing is your interface and if it has a control panel with routing options! But thats not a pro tools issue and unlikely to cause thus really.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-31-2012, 09:10 PM
Originally Posted by crizdee View Post
Chris
I have checked all of this and I don't think I have anything routed wrong with the tracks I'm recording in. It records all the tracks that I have audio clips on. The problem might be with my interface. I'll check and follow up.
Old 01-01-2013, 06:04 PM
You might also use photobucket(or similar) to upload and link to some screen shots showing your MIX window(where we can view all your routing) and a shot of your monitoring utility for your interface(which, BTW, we have no idea about)
Old 01-02-2013, 11:15 PM
Right lol..I am using a Focusrite Saffire 2i2. I have done some more testing and it seems that whatever is in my output is leaking into my recording input for tracks. I will try to post pics of the mix window but everything looks fine, input 1 for the track I'm recording on, the outputs are all on 1-2 stereo but it seems that's the problem. Any way to fix this?
Old 01-11-2013, 11:47 PM
zedhed's Avatar
zedhed zedhed is offline
Also a snapshot of your I/O settings
PT>Setup>I/O setup>input Tab as well as Output
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 09-12-2023, 02:51 AM
Tan Tan is offline
Hello, I recently ran into this problems too. May ask if you have solved the problems or not, how did you solve it ? Thanks a lot
[IMG] code is Off
Recording with instrument tracks and audio tracks Shan B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-01-2011 02:22 PM
audio input tracks sent to one aux track - how do i monitor JUST the aux input track? awhile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-17-2010 07:50 AM
Input for new Tracks. I need a tip. Kurty B Tips & Tricks 2 08-21-2006 12:17 PM
how to set some tracks in input without recording? david kowalski Tips & Tricks 8 11-18-2003 08:14 PM
Recording automation AT THE SAME TIME as recording tracks mikeb37 Tips & Tricks 3 03-13-2000 09:43 PM
