Old 09-15-2012, 07:48 AM
L-Train Studios L-Train Studios is offline
Angry Extended Window Problem PT 10.3
How do I get an extended window with 2 screens in Pro Tools 10.3?
I have it set to extended display and can't drag the mixer window on the second screen. I thought the upgrade from 10.2 fixed this? is there a shortcut or something? I'm not gonna reinstall just because of this one issue.
Old 09-15-2012, 08:15 AM
Default Re: Extended Window Problem PT 10.3
Have you done this before, or are you new to the game? Here's what USUALLY works: do not maximize the main PT window. Drag the edges of the main window out to fill both of your screens. Now drag the MIX and EDIT windows to the screen where you want them and drag their edges to fill each screen. Now close by hitting Alt-F4. It SHOULD open that way from now on.
Old 09-15-2012, 10:14 AM
cwsand's Avatar
cwsand cwsand is offline
Or are you trying to stretch the mix window across both screens? I think you could just move the window so that it's half on each screen, then drag the corners out on each monitor.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-18-2012, 09:32 AM
dafatboy dafatboy is offline
Look back a bit,,, we are all waiting for this issue to be fixed by Avid.
It doesn't happen on MAC, but windows 7 does not allow the mix or edit window be any larger than 1 monitor. There is no stretch across screens.
In the meantime I did buy a nifty program called skootch. (Users recommended it)
You may be interested also.
Google skooth for protools.
Old 09-18-2012, 10:11 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
It works perfectly here in 10.3. You can even move the mix and edit windows to each monitor and maximize them to that monitor. You just can't maximize the backdrop window which will limit it to one monitor.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 09-18-2012, 11:14 AM
Bob Nagy Bob Nagy is offline
For more information about Skootch, please contact me directly.
My email address is in my profile.
There is also a short video on YouTube showing some important features of Skootch. You can see it here :
http://youtu.be/lSITr74hP0I
Old 09-18-2012, 12:57 PM
Zarabozo's Avatar
Zarabozo Zarabozo is offline
I think this was solved on 10.3.
However, it's not exactly like "there's no stretch across screens". The actual thing is that it's been working for some graphic cards and not for others. I have an XFX ATI Radeon 5750 HD with 3 monitors (24'' 1920 x 1200 each) and I've been able to maximize everything across the 3 monitors since PT8 (and all versions of PT9 and PT10 to date). I was able to do it for 2 monitors with an nVidia GeForce GT220 too.
Francisco
The audio world is full of (mainly very expensive) placebos.
Windows 10 Pro 64 Bit
Pro Tools Ultimate (perpetual with active updates/support plan)
RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP)
Monitors: Yamaha MSP7 and Yamaha HS8S
Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! )
Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads)
128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each)
Boot disk: Samsung 980 Pro M.2 2TB
Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup
Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32''
Old 09-19-2012, 05:04 AM
ok,
this will be my last question about this.
Now look closely at this:
Can you take the MIX window and have it open all the way across 3 monitors on the BOTTOM half of the screen?
and the MIX window all the way across the TOP half of the 3 monitors?
Now on my computer (the same system both times) in Version 9 , I could do this all day.
UPgraded to version 10 no good. Limited to 1 monitor.
In the Guitar center system,,, on a MAC yes this can be done.
But on a PC, anyone?
Old 09-19-2012, 08:12 AM
I just read that 10.3 version fixes the monitor issue!!
I will try it tonight!
http://akmedia.digidesign.com/suppor..._Win_77550.pdf
Old 09-20-2012, 04:47 AM
Smile Re: Extended Window Problem PT 10.3
The update worked!!!
The check for updates from inside PT 10 didn't find anything, but at the avis site, PT 10.3 downloaded and installed, and the screens are fixed.
Thanks Avid!
Problem w/ PT8 LE v8.0.3/11 R No Window scottfree Pro Tools M-Powered (Mac) 4 09-30-2011 12:47 AM
G5 Dual Extended Monitor Problem SHUK Pro Tools TDM Systems (Mac) 3 02-04-2005 03:21 AM
Mac OsX Extended Journaled Problem Luis Miguel Storage Subsystems 4 11-03-2004 07:21 AM
Format Extended or Extended Journaled for PT6.2.3? AAR Pro Tools TDM Systems (Mac) 3 02-06-2004 07:46 AM
problem with size of mix window in 6.01 leftalive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-18-2003 02:38 PM
