Pro Tools 10 "quit unexpectedly" constantly after install!
hi there
please help me. i can't get pro tools to open. i have done a fresh install of pro tools 10 and every time i try to launch it quits when it gets to "setting up midi". we are running a mac pro (2 x 2.4ghz quad core, 8gb ram) mac os 10.6.8, mbox 2 pro. we also run a logic setup on the same computer with 2 x rme pcie madi cards and 2 x iz ada converters. this is a brand new install with no additional plug-ins etc. the mbox 2 is connected using a firewire 800 - 400 cable. there are no other firewire devices attached. the mbox appears in the system profiler. i'd be grateful for any help. |
Re: Pro Tools 10 "quit unexpectedly" constantly after install!
still got the same problem! anyone have any ideas? here is the beginning section of the "crash report":
Process: Pro Tools [229] Path: /Applications/Avid/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 10.0 (10.0f821) Build Info: Unknown-1000821~821 Code Type: X86 (Native) Parent Process: launchd [116] Date/Time: 2012-01-11 17:35:06.224 +0000 OS Version: Mac OS X 10.6.8 (10K549) Report Version: 6 Interval Since Last Report: 9532951 sec Crashes Since Last Report: 21 Per-App Interval Since Last Report: 308 sec Per-App Crashes Since Last Report: 18 Anonymous UUID: 5C9FD488-DC42-4204-A2C8-DBB2A00CE227 Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000028 Crashed Thread: 39 |
Can you show us thread 39 of the crash log. Are you absolutely certain there are no old/previous plugins still installed on the computer! Chris
This happened to me, it was a plugin causing the issue. I watched the loading screen, and determined which plugin was causing the crash (the one that was displayed as loading just before crashing) I removed that plugin, and presto, it worked.
How do I remove the plugin? Seems to be digirewire
thanks for the reply. here is the info... Thread 39 Crashed: 0 ??? 0x2a25a80b 0 + 707110923 there are some waves and uad plug-ins that we use for logic, could they be an issue? pro tools crashes at the point of "setting up midi", no plug-ins are listed during the boot and it doesn't get passed the "setting up midi" stage. we haven't had pro tools installed on this computer before. |
sorry, i just checked and a bunch of digidesign plug-ins are listed during the boot up. it seems to scan though them all ok, then dae, then the "setting up midi" at which point it quits.
I'm having the exact same issue on a macbook pro, running 10.6.8. I have a fresh install of pro tools 10, and I can't get past even the first half-second of the launch - it just quits.
I've tried repairing disk permissions, re-installing, rebooting, removing all the plugins and the result is the same. PT just won't boot at all. This is very frustrating, as I spent all this money to upgrade to a version of PT that is compatible with 10.6.8. Any help would be appreciated. |
I am having a different crash error though:
Process: Pro Tools [372] Path: /Applications/Avid/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 10.0 (10.0f821) Build Info: Unknown-1000821~821 Code Type: X86 (Native) Parent Process: launchd [166] Date/Time: 2012-01-12 17:29:51.590 -0500 OS Version: Mac OS X 10.6.8 (10K549) Report Version: 6 Interval Since Last Report: 2708190 sec Crashes Since Last Report: 35 Per-App Interval Since Last Report: 35 sec Per-App Crashes Since Last Report: 12 Anonymous UUID: CE96D273-2535-4F0B-B6F0-7F8939966832 Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000910b12e7 Crashed Thread: 0 Dispatch queue: com.apple.main-thread Thread 0 Crashed: Dispatch queue: com.apple.main-thread 0 ??? 0x0537c000 0 + 87539712 |
i'm surprised how many people seem to be having issues with this, reading elsewhere on the forum. surely it should just work after installation without any problems?
i wonder if someone at avid could offer some advice on this matter... |
Strange "Assertion" error causing Pro Tools to quit unexpectedly...???? | nickbradbury | macOS | 13 | 09-10-2014 03:50 AM |
"Pro Tools quit unexpectedly" a lot! | MidnightFlyer | Pro Tools 9 | 0 | 06-29-2013 03:05 PM |
"Pro Tools LE quit unexpectedly" tried every solution I can find.... | HorizonsDOUG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2011 11:06 AM |
"the application pro tools has unexpectedly quit" | lcovemusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-19-2010 12:33 PM |
"The application Pro Tools LE quit unexpectedly." | molossus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-19-2009 12:06 AM |
