Old 11-19-2011, 01:39 AM
maxspl maxspl is offline
Default Help with I/O Assignment for Tascam US-800 Interface
I am trying to use the Tascam US-800 with PT 9, and I am having an issue recording from all the inputs. The US-800 has 8 inputs, but I can only record inputs 1 & 2. The rest show as active inputs (yellow) that I can select and assign to tracks in the PT 9 edit window, but I get no signal from the mic. I know the mic inputs are working because I can see the levels on the software control panel for the interface, on the instrument front panel, and hear them through the headphone. I have also recorded each individual input with Cubase; so I know the hardware works.
I am using the ASIO4ALL driver to interface the US-800 with PT because of incompatible latency settings between the two. I have successfully recorded with the Tascam US-1641 interface with this configuration in PT with no issue and assumed that there would be no issue with the US-800.
I’m wondering if there is some issue with signal routing in PT that I’m overlooking. I read the PT9 reference and thought I assigned everything right, but I could have missed something simple. I would appreciate some help. Thanks.
Max
English!? Who needs that? I'm never going to England!
Homer Simpson
Old 12-29-2012, 06:40 PM
isherwoodme's Avatar
isherwoodme isherwoodme is offline
Default Re: Help with I/O Assignment for Tascam US-800 Interface
Hello Max, I'm having the same issue, did you get this figured out yet?
I had it working fine on my MacBook Pro until the cat peed on it. No more cat.
I installed PT9 on a new Windows machine and am using ASIO4ALL as well.
Thanks in advance for any help.
Keep In Tune!
isherwoodme
| 2022 DELL Windows 11 - 64G RAM
| Pro Tools Studio Perpetual & Active Sub
| TASCAM US-16x08
| TASCAM MH-8
| TASCAM US-1x2HR
| '78 Fender Jazz Bass FRETLESS
| '97 Squier P-Bass
| '00 5-String Squier Precision Bass Standard
| '20 Squier Contemporary Active Jazz Bass HH
| '20 Ovation CE48 Celebrity Elite Super Shallow
| '21 Squier Stratocaster - Sienna Sunburst with Maple Fb
Old 12-30-2012, 02:37 PM
crizdee's Avatar
crizdee crizdee is offline
Max
A few things to check..
In the hardware setup page. You have 8 inputs assigned to the analogue inputs on the tascam.
In the I/O setup page you have 8 inputs created and all assigned to the 8 inputs on the tascam.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-20-2022, 07:44 PM
Just saw this post. Figured since nobody posted the solution, that I would do it for posterity.
The TASCAM US-800 (I still have mine) won't work on modern versions of Windows (in Pro Tools specifically) because it has non-standard buffer sizes.
The only buffer sizes that will work with PT are 32(although I've had issues going that low),64,128,256,512,1024, & 2048
The US-800 has settings of 192,240,288,336,384,576
I think it will still work properly on a Mac (how I first used mine) because the Mac operating system takes control of audio drivers - or through ASIO4all for other DAWs because apparently, they're not that picky.
Hope it helps clear it up for someone.
Keep In Tune!
isherwoodme
| TASCAM US-16x08
| TASCAM MH-8
| TASCAM US-1x2HR
| '97 Squier P-Bass
[IMG] code is Off
Help! Tascam Interface, no Input into PT9! isherwoodme Windows 2 07-12-2021 11:28 AM
New Tascam interface UH7000 nst7 General Discussion 0 03-14-2014 07:58 AM
tascam interface compatibility krecneps macOS 0 10-06-2012 10:32 PM
Interface for Tascam Mixer Alagu Post - Surround - Video 0 01-12-2001 07:55 PM
Tascam USB Interface? TimNielsen Digidesign Hardware & Software 1 12-04-2000 08:29 PM
